TP-Link 510G Wireless PCMCIA Card with Wanadoo livebox (Setup ?)
Jan 04, 2006 3 Replies
Jump to replies (3)
I have been given a TP-Link TL-WN510G PCMCIA Wireless card which works in my Laptop (Using Windows XP), but I'm having problems getting it to work with my Wanadoo Livebox. Has anyone got a similar set-up and how did you go about setting it up?
Thanks
Graham
Did you follow these instructions.
I've tried both the instructions supplied with the card and those given by Wanadoo but neither seem to work, I'm trying to find if anyone else had the same sort of problems or whether there is a problem with my kit.
Thanks
Graham
Everyone I know that uses Wanadoo has had no problems setting up provided they followed the instructions exactly.Have you tried it on another network, a friends or a wifi hotspot?Can you borrow a different wifi card to try?
