Setting Up Wireless Network??
Oct 16, 2007 0 Replies
Hi, Have quite a complicated set up, as follows:
Main modem/router is a invertel orange livebox connected downstairs (All working fine) with IP 192.168.1.66
Laptop connecting fine to livebox, not sure if it is connecting to the Netgear
D-Link 301P+ ethernet print server with IP 192.168.1.15
Netgear wireless print server WGPS606 (Printer is not USB) with IP
192.168.0.102 connected fine with the livebox, (Has same SSID as livebox)
What I want to do is to connect the Print Server (PS) to the Netgear ..... so I can then print via laptop or any other wireless computer. The PS works fine when connected to laptop but not sure what to do next I have connected the PS via ethernet cable to the netgear..... but dont seem to be able to find the printer.
Printer is HP 5P and am running XP.
Think I am getting there but am struggling a little bit if anyone could help me with the correct settiings.
Thanks in advance for any help Olly
