Stop Unwanted Network
Jun 21, 2005 3 Replies
Jump to replies (3)
Every few minutes my PC will pick up what I assume to be a neighbors wireless signal and a screen will pop up. Can I disable my PC from detecting other networks. Windows XP SP1 with a built in wireless card using the default Windows configuration tool. Thanks
WindowsXP-SP2 will allow you to specify those "other" networks as manual connect. Then they won't bother you anymore. The only problem is if there is a network that you want, and a network that you don't want, that have the same SSID.
You can disable the Wireless Zero Configuration Service on XP that's making the machine seekout other networks and trying to connect to them. You disable WZCS and it will stop doing it -- period.
Duane :)
Thanks, I'll give it a try.
