reinstalled XP
Jul 06, 2007 3 Replies
Jump to replies (3)
dear people, just reinstalled a XP professional on my gf's Dell Inspiron600m.
That Laptop supposed to have an internal Wireless card. But now, all the network devices have yellow question marks.
Im not very much computer installer, nore network guru. Can anybody give me some directions? regrds, pablo
Yeah, you can post to a Microsoft.public.windows.XP NG.
pabloop hath wroth:
Microsoft advert: What do you want to reinstall today? Hint: The solution to all Windoze problems is not a reinstall.
Yep. Did you use the Dell (purple color) XP CD? You probably did because you didn't slam into a serial number problem. These Dell CD's come in various flavors (SP1, SP1.1, SP2), none of which are up to date. Start updating at:
Plan on spending anywhere from 3 to 5 hours doing nothing but updates.
As for drivers, look on the bottom of the laptop for the "service code". It will be 5-7 characters over a bar code. Go unto the support page at Dell for your laptop, inscribe the service code, and it will provide you with a nifty list of things to download, including the wireless driver.
Ummmm... right.
Yes, almost anyone can do that.
Dell Forums:
Dell Support:
Did you reinstall all the drivers from the drivers disk? It should be a blue and white disk. When you put it in it should come up with a list of drivers for your model. You probably don't have sound or full video.
If you don't have the disk you will have to find them on the Dell web site, You put in the service tag an if will give you a list of drivers for all different devices that could be installed in your laptop. You should have written them all down before you wiped it out.
