Making to Wireless routers connect?
Mar 13, 2005 4 Replies
Airhead
(wireless Its possible, is this your setup? dsl -> Wan port(DHCP on) ->Lan Port to Lan port(DHCP off).->Nic
(wireless
Not very likely as most routers can not be set for client mode.
Hi. Im not a newbie to networks, BUT a COMPLETELY newbie to WIRELESS networks... So here is my question:
The setup i Have now - Adsl connection -> Trendnet TEW-231BRP (wireless router) -> pc with DLink dwl-122.
This works fine.... BUT
Because of no driver-support for winXP64(wich i just installed) for the dlink, i would like to just use my second WLAN router (same as the other) to connect to my standard NIC on the computer .... I cant get this to work - shouldn't that be possible? And if so... How?
the setup i would like, was this:
dsl -> TEW-231BRP -> TEW-231BRP -> NIC in pc
Please forgive me my ignorance, but I cant see any reason, that this should not be an option?
Thanks in advance.
Martin
snipped-for-privacy@frederiksen.mail.dk
That really sucks doesnt it?? Well - thanks for the reply!
this is my setup now:
dsl -> Wan port (DHCP On)->Wireless (DHCP On)-> USB wireless device
