DLINK DWL-AG700AP problem
Mar 02, 2006 5 Replies
Jump to replies (5)
Hi, Has anyone experienced problems with DLINK DWL-AG700AP Access Point ? I can browse the internet but not intranet PCs. All my configurations seems to be ok (I posted on other forums before this) but nobody can give me a solution! I'll be glad to explain the problem in details (i.e. expalin exactly my configuration) if someone will try to help me.
Thanks.
You'll need to be a lot more specific if you want meaningful help.
Hi John,
Yes, of course, you need more hints. Can you please refer to this link for more specific details
(if broken)
post Thread: internet ok no lan
Thanks for your help.
wi-fi usb dongle too (DLINK AirPlus DWL-G112).
What's the switch hooked to.
network 192.168.0.X) mask 255.255.255.0 gateway 0.0.0.0 dns 0.0.0.0
Are you getting DHCP from a router on all computers?
Don't do this -- waste of time, will only cause grief.
OK.
and browsing the web (laptop and pc have gateway and dns settings as other pc on wired network) .
Everything manual on all computers?!
name) by the wi-fi interface.
and so on) but I had no result.
Sounds like the AP isn't working as a bridge, which is what you need.
Hi John,
It's a star network (quite simple, I think): These are the devices connected to the switch: .) 3 PCs (W2K) .) 1 CISCO SOHO 97 (gateway) .) 1 AP (the source of my problems !!!)
2 other PCs are are wifi connected to the AP.
No, I'm not using DHCP neither for wifi no for wired lan . All IPs are static ones. I tried this too, i.e. enabling the AP DHCP feature, but with no result.
I tried to disable MAC fitering , but nothing changed.
What do you mean with manual ? Wifi connection is automatic (i.e. laptop and usb dongle find the wifi and automatically connect without problems), gateway and dns setting are static (i.e. non DHCP)
Yes, I think too. I suspect the AP model isn't the right one. Can yo take a look at D-LINK specs ?
Thanks
Solved !
The matter was with a ethernet interface created by WMWare : It has same IP class as lan. When pathpinging I saw the route was to 192.168.0.2 (the WMWare eth IP) . I disabled It and now everything works fine !!!!
Thanks to everyone for help .
