Dlink : "Access Point" or "Wireless Client" mode?
Jan 08, 2005 2 Replies
Roby
Short answer: "Yes" Longer answer: You can configure it either way, with different results. Most likely, you want to be able to reach your ADSL connection and/or the other PCs in your wireless network. For that, set up the 2000AP+ as a Wireless Client. Roby
Short answer: "Yes"
Roby
I have a wireless modem/router at home (Dlink DSL G604T) and a PC with an access point (DSL-2000AP+) hanging off it's ethernet port. There are a couple of other PCs on the wireless network but they connect fine.
Do I configure the 2000AP+ as a "Wireless Client" or as an "Access Point" ? (It does bridging and something else too but that definately isn't it).
Confused, Alfie.
Thanks for the info. I'll give it a lash tomorrow.
Cheers, Alfie.
