dlink 624 - dlink 800ap
Jan 26, 2005 6 Replies
Jump to replies (6)
Hi to everybody
I am trying to connect two computer using the above products. The first one is connected to the 624 and the second to the 800Ap (as access point)
I can configure (using the cable) the two wireless products, but I am not able to connect them via wireless
If I connect via cable the 800AP to the 624 No problem, but if I try solo wireless, I am not able to connect the two computers.
schema
Linux Box --(cable)--> DI624 -----(wireless) ---- 800AP --(cable)-->PC
no working at all I've tried with DHCP on, DHCP off, WEP on/off ...
Any hint ?
Thanks a lot Bilo
The 800AP isn't a client, it's either an AP or a repeater, except that it doesn't work as a repeater...
You need a client (card, adapter, USB dongle) for your computer.
an access point is meant to be wired to your router for extended coverage area of your network. If your AP can be set to repeater mode, for extended range, or client mode, for using as a wirless adapter, then you should beable to connect wirelessly. Check with the D-Link web site to see if your hardware supports either or both of those modes.
"Robert Jacobs" wrote in news:isMJd.1376$2i4.411@trnddc01:
This is the description on the Dlink site
---------------- The DWL-800AP+ can be configured to perform as a wireless access point or as a repeater to another wireless access
Does it mean that I cannot use the kind of connection I need? I have to change the 800Ap with another product?
Thanks a lot Bilo
William P.N. Smith wrote in news:puffv0d5cd50gd44bdqfi9f1fqqagp9efc@
4ax.com:
thank, thank you very much for your help ....
Bilo
That shows that you can not use it as a client....
You will have to buy a USB adapter PCI adapter or a pcmcia card adapter to use as your client connection.
"Robert Jacobs" wrote in news:7FVJd.197$Eh5.0@trnddc04:
Thank you.
I bought the wrong thing. What I needed was the 810Ap NOT the 800AP
Thanks again for your answer
Bilo
