SPA-3000 Silent in PSTN Calls
May 12, 2005 3 Replies
Jump to replies (3)
I've got a strange problem with my Sipura SPA-3000. I can make VoIP calls without problems, but when I dial a number that is supposed to go through @gw0 (PSTN line), I cannot hear anything and cannot be heard by the callee. The phone basically goes silent for all PSTN calls. (In all cases, I am dialing using an analogue phone connected to SPA-3000's FXS)
Can anyone suggest why this happens and how it can be fixed?
Thanks a lot,
Serge
What does your VOIP provider have to say about this?
I'm testing two sipura 3000, and I have the same problem when I connect the SIpura with a PBX if I connect with a PSTN line all go in the right way. But how do you do to connect to the PSTN line?
Thank you .
Cristian
What would they have to do with it?
miguel
