DVG-1402S and DI-784 - intriguing problem - advice please!
Sep 03, 2005 2 Replies
I have a D-link DI-784 Wireless router. I only have one wireless machine (laptop) and then 3 wired connections. I use the DI-784 router because of its simple built in DDNS feature.
I bought the DVG-1402S device. My VOIP service is working, however here is my issue...
If I put the VOIP router first, like I would prefer to do, and then output from there to my DI-784, then my DI-784's built in DDNS will not resolve to my public internet IP, but instead it tries to resolve to its own internal IP that was issued to it from the DVG device. This prevents me from doing anything with my DDNS domain name. Even if I just ping my DDNS name from another PC on the internet somewhere, it tells me it is trying to resolve to 192.168.15.whatever.
If I put the DI-784 first so I can still use DDNS, then I lose the ability to prioritize traffic over the DVG device...
So then I decided to just run my DI-784 router first, then only have my wireless laptop connected to it, and then plug all the other machines into the DVG device so at least they will be prioritized. Whenever they get the default IP from the DVG device (plugged in in this manner) those machines are on a different sub-net than the laptop, and I am unable to network between the PC's. I then tried changing the settings on the DVG device to try to place the machines plugged into it on the same subnet. This allowed my machines to network, but for some reason, I cannot connect to the admin page on the DVG device (I made sure it had a different IP than my DI-784 does, but I still cannot connect.
And for some reason now, with my DI-784 plugged in first, I have noticed now that incoming calls on the caller ID are being displayed as coming from 4 hours in the future...so I don't know what to do to fix that.
Does anyone see a way I could put the DVG first and still be able to use the DDNS feature of the DI-784? Or if not, is there at least a way I can set it up so all machines would be networked and I could still connect to the admin page of the DVG?
Any help is greatly appreciated!
Thanks!
I was going to read your entire post, then I saw D-link. If you want to avoid a huge headache, don't use D-link. As for your calls from the future, check the time zone settings on your voip device (if it has them). Be careful though, the thing might crash because you clicked submit when the activity light flashed. (ok yeah I read most of your post) I'd suggest just disabling the NAT features in your router and using it as a wireless access point only, then use the voip device as a router. You'll want to disable DHCP too. As for your dynamic DNS, use a windows based client. Good luck
I already have d-link and probably won't swap out anytime soon. I picked them because of price, and for the most part they work great.
I had to adjust the time zone settings like you said, but had to pick atlantic rather than EST to get it to come up right, despite the fact I live in EST...
If I ever change routers, I may spend the extra money then to get something better...
