Wireless Security system info wanted
Mar 10, 2006 69 Replies
Where in NYC?
Crash Gord> LI
I had a loft on the N/W corner of Mulberry & Canal for couple of years, then apt on 29th St bet. 2nd & 3rd next to the firehouse.
| > | > | > | > | > snipped-for-privacy@test.com wrote: | > | > | > | > | >
| > | > | > | > | >>Yep, i do post post in the rec.aviation sites once and | > awhile. | > | > | > | > | >>I talked with a friend who does alarm stuff for a living and | > he | > | > | > | > | >>suggested the Ademco. | > | > | > | > | >>
| > | > | > | > | >>I really don't have a way to run a cable for the key pad to | > the | > | > | > front of | > | > | > | > | >>the house. He suggested the FOB for entry and having the | > keypad | > | > in | > | > | > the | > | > | > | > | >>rear of the house closer to the control head. (the only | > place i | > | > can | > | > | > run | > | > | > | > | >>wire due to 2-story and tile floors) | > | > | > | > | >>
| > | > | > | > | >>I will do monitoring, its cheaper than I thought and the | > | > insurance | > | > | > | > | >>discount will cover most of the cost. | > | > | > | > | >>
| > | > | > | > | >>Thanks for the help, all. | > | > | > | > | >>
| > | > | > | > | >>Dave | > | > | > | > | >>
| > | > | > | > | >>P.S. I don't know Bass, unless he's the guy posting for | > Belfort | > | > | > | > instruments. | > | > | > | > | >>
| > | > | > | > | >>Mr.Double-sided tape wrote: | > | > | > | > | >>
| > | > | > | > | >>>I see you also post to rec.aviation. Ask those folks in | > there | > | > about | > | > | > | > | >>>this guy Bass. He was the ultimate rec.aviation troll. They | > | > used to | > | > | > | > | >>>call him BoBo. He was a student pilot who posted as if he | > were | > | > | > Orville | > | > | > | > | >>>Wright himself. | > | > | > | > | >>>
| > | > | > | > | >>>As for the DIY alarm, unless you really know how to run a | > wire | > | > | > without | > | > | > | > | >>>going staple gun crazy then hire an alarm company to do it. | > | > It's | > | > | > really | > | > | > | > | >>>not worth it on the DIY side. You save a few hundred bucks | > but | > | > lose | > | > | > | > | >>>precious time reading manuals and trying to figure out how | > to | > | > | > install | > | > | > | > | >>>the system, when for the few extra bucks someone who knows | > what | > | > | > they | > | > | > | > | >>>are doing can have your system up and running within hours. | > | > | > | > | >>>Tell me what State you are in and I'll help you find a | > decent | > | > | > company. | > | > | > | > | >>>
| > | > | > | > | >>> snipped-for-privacy@test.com wrote: | > | > | > | > | >>>
| > | > | > | > | >>>>One of my neighbors was probably in the house, or at least | > her | > | > | > | > daughter | > | > | > | > | >>>>who has a drug problem. Thats one of my problems. | > | > | > | > | >>>>The other neighbor doesn't have much visability to my | > entrance | > | > | > ways. | > | > | > | > | >>>>
| > | > | > | > | >>>>Your probably right on the monitoring service. I'll look | > into | > | > it!! | > | > | > | > | >>>>
| > | > | > | > | >>>>Thanks | > | > | > | > | >>>>
| > | > | > | > | >>>>Dave | > | > | > | > | >>>>
| > | > | > | > | >>>>Mr.Double-sided tape wrote: | > | > | > | > | >>>>
| > | > | > | > | >>>>>Where were the neighbors during the burglary? | > | > | > | > | >>>>>Check their next tag sale and you'll see everything you | > are | > | > | > missing. | > | > | > | > | >>>>>I'm not one to gossip but word on the street says the | > | > neighbors | > | > | > have | > | > | > | > | >>>>>been casing your crib since the day you moved in. | > | > | > | > | >>>>>
| > | > | > | > | >>>>>Whatever alarm system you choose to have installed make | > sure | > | > it | > | > | > is | > | > | > | > | >>>>>monitored! | > | > | > | > | >>>>>
| > | > | > | > | >>>>> snipped-for-privacy@test.com wrote: | > | > | > | > | >>>>>
| > | > | > | > | >>>>>>Frank Olson wrote: | > | > | > | > | >>>>>>
| > | > | > | > | >>>>>>> snipped-for-privacy@test.com wrote: | > | > | > | > | >>>>>>>
| > | > | > | > | >>>>>>>>Hi, | > | > | > | > | >>>>>>>>
| > | > | > | > | >>>>>>>>I need a security system and have been looking at the | > | > Ademco | > | > | > | > LNXRPK, | > | > | > | > | >>>>>>>>Visionx PowerMax, Napco P3200 and DSC PC5020. | > | > | > | > | >>>>>>>>
| > | > | > | > | >>>>>>>>The house is two stories about 1800 sqft with about 20 | > | > | > windows. I | > | > | > | > | >>>>>>>>figured that two motion alarms with wireless entrance | > | > alarms | > | > | > for | > | > | > | > the | > | > | > | > | >>>>>>>>two downstairs entrances would cover most of the | > house. | > | > | > | > | >>>>>>>>Also I would like to have a smoke alarm and a wireless | > | > remote | > | > | > | > siren. | > | > | > | > | >>>>>>>>
| > | > | > | > | >>>>>>>>I'm not going to have the system monitored at this | > point, | > | > but | > | > | > will | > | > | > | > | >>>>>>>>have it call me or my neighbors when an alarm gets | > | > detected. | > | > | > | > | >>>>>>>>
| > | > | > | > | >>>>>>>>Any of the above mentioned systems standout better | > than | > | > the | > | > | > | > others? | > | > | > | > | >>>>>>>>
| > | > | > | > | >>>>>>>>Is there another system I should look at? | > | > | > | > | >>>>>>>>
| > | > | > | > | >>>>>>>>Thanks in advance! | > | > | > | > | >>>>>>>>
| > | > | > | > | >>>>>>>>Dave | > | > | > | > | >>>>>>>>
| > | > | > | > | >>>>>>>Scroll up a little and have a look at the thread about | > "DIY | > | > | > | > | >>>>>>>recommendations requested". | > | > | > | > | >>>>>>>
| > | > | > | > | >>>>>>>Frank Olson | > | > | > | > | >>>>>>>
| > | > | > | > | >>>>>>Frank, | > | > | > | > | >>>>>>
| > | > | > | > | >>>>>>i saw the thread, but it didn't address my needs. | > | > | > | > | >>>>>
| > | > | > | > | >>>>>>From What I've seen only Ademco has a wireless keypad, | > but | > | > it | > | > | > | > doesn't | > | > | > | > | >>>>>
| > | > | > | > | >>>>>>have a cabinet for the CPU. | > | > | > | > | >>>>>>I'm new at this, just had my house burglerized this week | > and | > | > | > looking | > | > | > | > for | > | > | > | > | >>>>>>a solution. | > | > | > | > | >>>>>>I need pretty much wireless everything. No basement or | > | > | > availablity | > | > | > | > to | > | > | > | > | >>>>>>the attic for wiring. The mounting of the CPU and keypad | > in | > | > | > | > different | > | > | > | > | >>>>>>sides of the house. | > | > | > | > | >>>>>>
| > | > | > | > | >>>>>>I wish I had more flexability for more of a hybrid | > system. | > | > | > | > | >>>>>>
| > | > | > | > | >>>>>>If I was in a single story or had a basement, i'd be in | > high | > | > | > cotton. | > | > | > | > | >>>>>>
That one is easy. Split the system into two partitions. Come back when you know enough about Napco to ask a challenging question.
Anywhere near Smithtown, LI?
I went to high school on 59th near Lex, right around the corner from Bloomie's. After school each day a bunch of us would take the subway down to St. Mark's and hang out on the Lower East Side.
My first apartment was on 10th between 1st and A. That was in the late 60's. There were about 10 people sharing the place plus a few dozen friends who'd come in on weekends. The last place I had in Manhattan was on 14th St, across from The Dom nightclub, same era.
I lived and worked in NYC for a while in the mid 70s. The last place I worked before leaving NY forever was 350 Fifth Avenue. You probably know the place. :^)
I thought you were in Scottsdale Az.?
Nope. Salvador, Brasil at the moment. Usually in Sarasota, Florida when I'm in the States. :^)
10th & A...borderline "yikes" neighborhood. I went to university on 7th & 1st Ave...and basically lived in McSorley's pub.
No I'm broke live most everyone else these days. Lofts were pretty cheap back then, this was back in the early 70's...loft living was just beginning. We had 2000 sq ft...the entire 3rd floor.
| > | > | > | > "Mr.Double-sided Tape" wrote in message | > | > | > | > news: snipped-for-privacy@e56g2000cwe.googlegroups.com... | > | > | > | > | Good LORD Crash if the poor guy had to wait for your advice | > he'd | > | > be | > | > | > | > | dead of old age. He asked that question like ten years ago. | > Stop | > | > | > fotzin | > | > | > | > | around with Campbell and get back to posting :-) | > | > | > | > | | > | > | > | > | Crash Gordon wrote: | > | > | > | > | > If you pull up a small section of carpet at a time and put | > it | > | > right | > | > | > back | > | > | > | > on | > | > | > | > | > the tack strips as you go you might get away without using a | > | > carpet | > | > | > | > kicker. | > | > | > | > | >
| > | > | > | > | > | > snipped-for-privacy@test.com wrote: | > | > | > | > | > | >
| > | > | > | > | > | >>Yep, i do post post in the rec.aviation sites once and | > | > awhile. | > | > | > | > | > | >>I talked with a friend who does alarm stuff for a living | > and | > | > he | > | > | > | > | > | >>suggested the Ademco. | > | > | > | > | > | >>
| > | > | > | > | > | >>I really don't have a way to run a cable for the key pad | > to | > | > the | > | > | > | > front of | > | > | > | > | > | >>the house. He suggested the FOB for entry and having the | > | > keypad | > | > | > in | > | > | > | > the | > | > | > | > | > | >>rear of the house closer to the control head. (the only | > | > place i | > | > | > can | > | > | > | > run | > | > | > | > | > | >>wire due to 2-story and tile floors) | > | > | > | > | > | >>
| > | > | > | > | > | >>I will do monitoring, its cheaper than I thought and the | > | > | > insurance | > | > | > | > | > | >>discount will cover most of the cost. | > | > | > | > | > | >>
| > | > | > | > | > | >>Thanks for the help, all. | > | > | > | > | > | >>
| > | > | > | > | > | >>Dave | > | > | > | > | > | >>
| > | > | > | > | > | >>P.S. I don't know Bass, unless he's the guy posting for | > | > Belfort | > | > | > | > | > instruments. | > | > | > | > | > | >>
| > | > | > | > | > | >>Mr.Double-sided tape wrote: | > | > | > | > | > | >>
| > | > | > | > | > | >>>I see you also post to rec.aviation. Ask those folks in | > | > there | > | > | > about | > | > | > | > | > | >>>this guy Bass. He was the ultimate rec.aviation troll. | > They | > | > | > used to | > | > | > | > | > | >>>call him BoBo. He was a student pilot who posted as if | > he | > | > were | > | > | > | > Orville | > | > | > | > | > | >>>Wright himself. | > | > | > | > | > | >>>
| > | > | > | > | > | >>>As for the DIY alarm, unless you really know how to run | > a | > | > wire | > | > | > | > without | > | > | > | > | > | >>>going staple gun crazy then hire an alarm company to do | > it. | > | > | > It's | > | > | > | > really | > | > | > | > | > | >>>not worth it on the DIY side. You save a few hundred | > bucks | > | > but | > | > | > lose | > | > | > | > | > | >>>precious time reading manuals and trying to figure out | > how | > | > to | > | > | > | > install | > | > | > | > | > | >>>the system, when for the few extra bucks someone who | > knows | > | > what | > | > | > | > they | > | > | > | > | > | >>>are doing can have your system up and running within | > hours. | > | > | > | > | > | >>>Tell me what State you are in and I'll help you find a | > | > decent | > | > | > | > company. | > | > | > | > | > | >>>
| > | > | > | > | > | >>> snipped-for-privacy@test.com wrote: | > | > | > | > | > | >>>
| > | > | > | > | > | >>>>One of my neighbors was probably in the house, or at | > least | > | > her | > | > | > | > | > daughter | > | > | > | > | > | >>>>who has a drug problem. Thats one of my problems. | > | > | > | > | > | >>>>The other neighbor doesn't have much visability to my | > | > entrance | > | > | > | > ways. | > | > | > | > | > | >>>>
| > | > | > | > | > | >>>>Your probably right on the monitoring service. I'll | > look | > | > into | > | > | > it!! | > | > | > | > | > | >>>>
| > | > | > | > | > | >>>>Thanks | > | > | > | > | > | >>>>
| > | > | > | > | > | >>>>Dave | > | > | > | > | > | >>>>
| > | > | > | > | > | >>>>Mr.Double-sided tape wrote: | > | > | > | > | > | >>>>
| > | > | > | > | > | >>>>>Where were the neighbors during the burglary? | > | > | > | > | > | >>>>>Check their next tag sale and you'll see everything | > you | > | > are | > | > | > | > missing. | > | > | > | > | > | >>>>>I'm not one to gossip but word on the street says the | > | > | > neighbors | > | > | > | > have | > | > | > | > | > | >>>>>been casing your crib since the day you moved in. | > | > | > | > | > | >>>>>
| > | > | > | > | > | >>>>>Whatever alarm system you choose to have installed | > make | > | > sure | > | > | > it | > | > | > | > is | > | > | > | > | > | >>>>>monitored! | > | > | > | > | > | >>>>>
| > | > | > | > | > | >>>>> snipped-for-privacy@test.com wrote: | > | > | > | > | > | >>>>>
| > | > | > | > | > | >>>>>>Frank Olson wrote: | > | > | > | > | > | >>>>>>
| > | > | > | > | > | >>>>>>> snipped-for-privacy@test.com wrote: | > | > | > | > | > | >>>>>>>
| > | > | > | > | > | >>>>>>>>Hi, | > | > | > | > | > | >>>>>>>>
| > | > | > | > | > | >>>>>>>>I need a security system and have been looking at | > the | > | > | > Ademco | > | > | > | > | > LNXRPK, | > | > | > | > | > | >>>>>>>>Visionx PowerMax, Napco P3200 and DSC PC5020. | > | > | > | > | > | >>>>>>>>
| > | > | > | > | > | >>>>>>>>The house is two stories about 1800 sqft with | > about 20 | > | > | > | > windows. I | > | > | > | > | > | >>>>>>>>figured that two motion alarms with wireless | > entrance | > | > | > alarms | > | > | > | > for | > | > | > | > | > the | > | > | > | > | > | >>>>>>>>two downstairs entrances would cover most of the | > | > house. | > | > | > | > | > | >>>>>>>>Also I would like to have a smoke alarm and a | > wireless | > | > | > remote | > | > | > | > | > siren. | > | > | > | > | > | >>>>>>>>
| > | > | > | > | > | >>>>>>>>I'm not going to have the system monitored at this | > | > point, | > | > | > but | > | > | > | > will | > | > | > | > | > | >>>>>>>>have it call me or my neighbors when an alarm gets | > | > | > detected. | > | > | > | > | > | >>>>>>>>
| > | > | > | > | > | >>>>>>>>Any of the above mentioned systems standout better | > | > than | > | > | > the | > | > | > | > | > others? | > | > | > | > | > | >>>>>>>>
| > | > | > | > | > | >>>>>>>>Is there another system I should look at? | > | > | > | > | > | >>>>>>>>
| > | > | > | > | > | >>>>>>>>Thanks in advance! | > | > | > | > | > | >>>>>>>>
| > | > | > | > | > | >>>>>>>>Dave | > | > | > | > | > | >>>>>>>>
| > | > | > | > | > | >>>>>>>Scroll up a little and have a look at the thread | > about | > | > "DIY | > | > | > | > | > | >>>>>>>recommendations requested". | > | > | > | > | > | >>>>>>>
| > | > | > | > | > | >>>>>>>Frank Olson | > | > | > | > | > | >>>>>>>
| > | > | > | > | > | >>>>>>Frank, | > | > | > | > | > | >>>>>>
| > | > | > | > | > | >>>>>>i saw the thread, but it didn't address my needs. | > | > | > | > | > | >>>>>
| > | > | > | > | > | >>>>>>From What I've seen only Ademco has a wireless | > keypad, | > | > but | > | > | > it | > | > | > | > | > doesn't | > | > | > | > | > | >>>>>
| > | > | > | > | > | >>>>>>have a cabinet for the CPU. | > | > | > | > | > | >>>>>>I'm new at this, just had my house burglerized this | > week | > | > and | > | > | > | > looking | > | > | > | > | > for | > | > | > | > | > | >>>>>>a solution. | > | > | > | > | > | >>>>>>I need pretty much wireless everything. No basement | > or | > | > | > | > availablity | > | > | > | > | > to | > | > | > | > | > | >>>>>>the attic for wiring. The mounting of the CPU and | > keypad | > | > in | > | > | > | > | > different | > | > | > | > | > | >>>>>>sides of the house. | > | > | > | > | > | >>>>>>
| > | > | > | > | > | >>>>>>I wish I had more flexability for more of a hybrid | > | > system. | > | > | > | > | > | >>>>>>
| > | > | > | > | > | >>>>>>If I was in a single story or had a basement, i'd be | > in | > | > high | > | > | > | > cotton. | > | > | > | > | > | >>>>>>
No. Syosset. Worked at the Smithtown Radio Shack once though :-)
I am now.
| > Anywhere near Smithtown, LI? | >
| > Regards, | > Robert L Bass | >
| > Bass Burglar Alarms | > The Online DIY Store | >
| > Never underestimate the power of very stupid people in large groups. | |
It wasn't even borderline in those days. There was a lot of violent crime. Do you remember the rich socialite girl from Greenwich, CT who was killed with her boyfriend down there in
1968? It made national headlines because her family was politically connected. They were friends of mine; sometimes stayed in our apartment.
I've never been in McSorley's but I knew the Dom, Electric Circus, Filmore East and a few other music/dance places well. There was a really weird club called The Cave on 11th or 12th and Ave A. Ever been there?
Another strange hangout in the Village was the Diggers' Free Store where everything was free. People just brought stuff they didn't need and left it, sometimes taking something else that they did need. The street kids would come in all the time and we'd feed them. If you'd met me then you would never have guessed that I'd be running an alarm company decades later. :^)
It's all a matter of timing. A cousin of mine bought a loft in Soho about 25-30 years ago for ~$20,000. He sold it recently for about $1.5M.
Another cousin, actually my second cousin, Howard received a substantial gift from his dad when he graduated college many years ago. He was a loner -- only wanted a place where no one would bother him. He took the money, found an obscure little town in Colorado and bought up land on both sides of the street. There he stayed. Perhaps you've heard of that little town. It's called Aspen. :^)
Some people have all the luck.
Syosset is a well known location in this trade. :^)
You just knew bAss was going to make up some wild story about New York exploits, didn't you? Here's a nice song for you that was written by bAss.
've%20Been%20Everywhere%20_%20Johnny%20Cash.wma
Crash Gord> 10th & A...borderline "yikes" neighborhood.
Not you Robert, I thought Crash Gordon was the one posting the comment about living in New York. I remembered his saying he lived in Scottsdale.... Allan
It seems a lot of people have trouble staying alive around you.
