Suggestions for Monitoring Doggie Door
Oct 23, 2007 1 Replies
I have a doggie door at the end of the short leg of an L-shaped hallway. I suspect that I will only be able to use a motion sensor to monitor only one end of the hallway (approx 3'x10') or is there a motion sensor that can be placed at the vertex of an L-shaped hallway and monitor both legs? Right now I am planning on using the Honeywell
5890pi .
Look at the Visonic PIR's. They have a lens library that will knock your socks off (including one which will do what you want). :-)
