What do I need to add keyfobs to a DSC Power 832 PC 5010. Currently has no wireless capability. TIA
power832
Jan 20, 2007
Most relevant reply
I just installed a PC5102-433 receiver and some WLS-919-433 fobs on my PC5010 system and it works fine. The receiver also has 2 relay outputs, so you can assign one of the buttons to trigger your electric garage door opener if you want. You easily usually find this stuff onβ¦
PC-5349. It's a wireless receiver. It's also compatible with the newer stuff from DSC and can "talk" to both 433 MHz and 900 MHz devices.
cool. it says button 1 is "alarm on-stay". does that mean it can't be armed to away?
great. that and a 4939-433 fob? I am looking at website that lists a
5108WKK1-433 kit with transmitter and reciever, says its power series compatible. Is that correct?You might try a Street Smart Code encryptor.
They are very easy to add into a system if you only want a remote and not adding any wireless zones. you do not even have to enter the panels programming.
I have never used that module, but dosent it just pair an old reciever and a new reciever on the same system? I did not think that it is a reciever in itself.
A momentary press of button 1 arms in the away mode. Holding the button down for a couple seconds arms in stay. js
message
You need either a 5108, a 5132 or if you want one in a keypad the older RF5501 or PK55xx series
You are correct, it bridges (badly) 433 and 900mhz sensors
message
Whoops! My "bad"... :-)
kewl
How long did you say you worked with DSC?
About as long as you worked with Napco.
You easily usually find this stuff on eBay for fairly cheap.
