Yes it does.
Yes it does.
I was working with V1
It had another problem too, but for the life of me, I can't remember what it was. Maybe they fixed that too.
Sure, and they do a quater the things a Napco panel will do. Dumb is as dumb does. You sure must have a lot of idiot customers. I don't know of anyone in my area that still does keypad programing on any sizeable panel.
What are you ..... contrary Mary?
I said it's a 9 volt unit and can't be powered from the control panel.
You said it's 9 volts to 16.5 and can be indirectly powered through a daisy chain setup.
How is that different than what I said? Anything can be indrectly powered from anything else if you add some sort of conversion of energy device.
Is it a 12vcd unit? No. Can it be powered from the control panel? No. Can it use the control panel standby battery? No.
Only if you have a converter an inverter a daisy chain, a 16.5 volt source a hand generator, and a piece of silk and a glass rod and a penny in some lemon juice. Jeeeeeeeze!
Since I never played with V1 I don't know what problems they had either
The transformer goes to the panel then the GSM radio daisy chained, I agree with you tho that it didn't make sense to not make it powered by the aux bus considering it uses less power than the old unit that could be powered by the panel however one thing I've seen a lot of with cell units of all brands is people tend to overload the panel, for that reason alone I'd rather it have it's own power supply like TelGuard
BTW Was StarLink what you were talking about?
Yes to the second part
It doesn't need one, it has it's own
Uh yea I guess, who's being the contrary Mary?
No it doesn't, I know they list a lot of panels on the site but at the moment it only supports Ademco 15P/20P and DSC Power series.
Well then, maybe you otta call them up and ask them. I posed as an end user and asked about it's capabilities and told them I had a Napco
9600. They said it would work with their device. So maybe it's their " V2" etc. I didn't ask about their V1
No. Star Link is their Radio.
How can it be powered from the contrl panel. It can't unless it has some diddly wink converter attached to it.
If it could be powered from the control panel, it wouldn't need it's own.
They only have 1 version and it doesn't support Napco yet, but hey now would be a great time for you to test it wouldn't it?
I only know what the guy told me. The 9600 was compatable, according to him.
Not likely I'd test it. A lot to do with the fact that central stations that aren't in my area don't give me what I want. Clients like the fact that their central is local. I like the fact that I can meet the operators, drop off gifts during the holidays, buy an occasional lunch and knowing that the manager knows that I can come down there in no time to find out what the f*ck is going on! There's no such thing as a disinterested operator or unresponding manager at any of my centrals. Ive met and had lunch with all of them.
It wouldn't be the same with someone I've never met, who's 1000 miles away, who knows that I"M a 1000 miles away.
I got a "Little Buttie" buttset last year from a guy in your area, does that count?
What does that have to do with uControl?
True, you'd have to be really pissed to drive a thousand miles to chew out a manager
Yeh ..... I'd imagine you did.
Only if he sent you flowers the next day.
I wouldn't have them monitor my accounts with their device.
Yep.
