which
The hardwired lighting/dimmer world has a swiss army knife converter (the Leviton-NSI I/F 501 Control Interface ) that converts back and forth in various configurations between:
Micro-plex DMX512 AMX192
0-10vdc analog MIDI LumaNet including contact closures RS-232as well as other tricks like cue programs and chases.
But that won't solve your problem. Some bright boy may make available a protocol splitter/converter that accepts CM11a input and outputs CM11a and other protocols like DMX and UPB along the lines of what I suggested in this newsgroup 3-1/2 years ago.
This could be implemented in PC software using a virtual COM port for the input, or with a microprocessor w/ firmware and hardware inputs and outputs
RS-232 ---> Splitter/converter ---> RS-232 ---> CM11a ---> RS-232 ---> DMX512 ---> RS-232 ---> Centralite ---> RS-232 ---> UPB ---> USB ---> etc
In this way the wide range of HA software that supports CM11a could instantly support other lighting schemes. ELK-M1G implements something not too dissimilar internally and allows (if I understand the documentation) for user-written ASCII command sets to support lighting protocols other than the
4-5 it supports natively...... Marc Marc_F_Hult
