Zone alarm and a PDA
Mar 04, 2006 5 Replies
Jump to replies (5)
I am trying to connect a PDA to my PC but zone alarm will not let them connect. If I disable ZA there is no problem. Could anybody please tell me the settings I require to allow connection?
Regards
Tony
Then you have your solution already.
Yours, VB.
He did give you a sensible answer.
Is your cable modem connected directly to your PC?
Jason
If you don't know how to use ZA then call ZA.
Duane :)
What Windows version do you use? If it's Windows XP, just use the Windows-Firewall.
Yours, VB.
