Zone Alarm & Skype
Sep 10, 2006 15 Replies
Jump to replies (15)
I have ZoneAlarm V 6.5.731.000 (Free version, not the Pro) and Windows XP. I am not able to get Skype to work with it.
Skype works fine when ZoneAlarm is shutdown. But when ZonaAlarm is running, it immediately makes my Skype off-line; when I try to set it to on-line nothing happens. I cannot do the Skype Test call - green phone is greyed out, I cannot click it.
Skype's on-line documentation says I should go to my Zone Alarm and within Programme Control change the access to a tick mark - but there is no entry for Skype there. It won't allow me to add an entry for Skype - nothing happens when I add the entry.
Any help would be appreciated.
Regards - JW
Sincere condolences.
Why not just using the Windows-Firewall then?
Yours, VB.
Refer to
to see what ZoneAlarm stops that Windows Firewall doesn't.
Regards - JW
And then we are - once again - back in the good old and everlasting discussion about the reliability of "outbound connection control".
/B. Nice
From that:
| Software firewalls do something that SP2's firewall does not do--block | and filter outbound connections as well.
Why filtering outbound is useless and even counterproductive, you can read in many threads here.
Yours, VB.
Did you install ZA as admin and Skype while as a user? That could cause what you are (not) seeing.
"ArtDent" wrote
To make sure, I uninstalled Skype and reinstalled it while as Admin user. Same result as before. I shutdown ZA, now I can do a Skype Test Call successfully. Then started ZA, now Skype Test Call doesn't work. Put Skype in offline then tried to get back to on-line - it stays off-line. Exited Skype, restarted it - can't logon, ZA has blocked communication to Skype server.
Regards - JW
Can you see it in the program list now? To change its permissions manually? I presume / hope it isn't that you installed ZA as user.
Why don't you try posting to a ZA NG where they can help you.
Duane :)
"ArtDent" wrote
No, I cannot see it.
No, I installed ZA as admin.
Regards - JW
"Duane Arnold" wrote
There isn't any ZA NG - I thought this one was the closest to the topic. Please let me know if I am wrong.
Regards - JW
long
short
Google is your friend.
Duane :)
John Wright schrieb:
So you found the cause yourself. Why do you ask here?
Regards Thomas
I think Duane is right that your best help would probably come over in that ZA forum. Do a search there to see if anybody else has had the same problem and if they were able to resolve it. If nothing, then ask there. It could be something simple, it could be something 'tricky', it could be an incompatibility that will need a patch from either Skype or ZA or both. I know this isn't all that helpful, but maybe get you pointed in the right direction at least. I don't remember if you said, did you email both their support@'s about this?
Skype uses ports 80+443, so you need to allow in/out any ip ports 80,443 you may also need to PORT FORWARD these ports in your router
fyi: google for 'Skype port usage'
(sorry the boys like to play king of the mountain here instead of addressing your needs)
"Jeff B" wrote
I simply uninstalled ZA and re-installed it, and Skype works perfectly now, there is indeed an entry in the Programme Control list now. Don't know why it didn't work with the version I had before, which was up-to-date.
Thanks very much for your helpful remarks.
Regards - JW
