Trust ip-address in a specific folder?
Sep 07, 2005 3 Replies
Leythos
First, you are looking at it wrong - Admins have access to all files/folders, even if you take permission away from them they can regain it at any time. If you want to share a folder based on a user name, then you want FTP. No firewall is going to limit users to a FOLDER on a…
Hello all,
Is there a firewall in which a certain ip-address can be set as "trusted" for a specific folder on the hard disk of a pc? The firewall I know (Norton IS) can set ip-addresses as trusted, but that goes for the entire pc (that is if the folders have been set to "shared" in Windows of course), not in a specific folder as far as I know.
Reason for this question: We have a home network (with neighbours) with 5 pc's including one backup pc. I want one pc (let's say pc A) in the home network to be able to reach only one folder (let's say folder A) on the backup pc. Therefore I created a user+password for the user of pc A and gave rights to this user to only folder A on the backup pc. But now the problem comes up: there is also an admin user that has full rights on the entire backup pc. What I want is that the admin user can only access folder A when logging in from pc A. This will increase the integrity of the "system". Since I am part of this system (I happen to be the admin-user) I do not want to be able to access folder A, not even as an admin-user, only when logging in from pc A. Clear? :-))
No firewall is going to limit users to a FOLDER on a node, that's the function of File/Folder permissions.
It is not sensibly possible to have constraints for administrative users. You'll better forget that.
Yours, VB.
Thanks guys. I will forget about this. In fact I already did. The solution I found in order to NOT let the admin be able to read the files in the neighbours backups is to create encrypted backups. Every neighbour knows only his own decrypt-password. The admin can reach the files but not read them. Works fine for me.
