Kerio interfering with XP Pro SP2
Oct 28, 2006 2 Replies
From locking an uninstallation routine of another program, to preventing ATI Tray Tools profile shortcuts from functioning, I've now discovered that Kerio is causing XP to slow to a crawl when trying to change XP's colour scheme.
For example, it takes about 30 seconds to change from Olive Green to Silver. The screen slowly fades to grey the fails to respond for a while unless I Ctrl-A-D. If I close Kerio, the the scheme changes over in an instant.
I simply can't find any function within Kerio that could be causing all this! Anybody else know why this is happening?
Which version of Kerio are you using? I'm using 2.1.5 on an XP sp2 box and everything seems normal.
You guess wrote: > Which version of Kerio are you using? I'm using 2.1.5 on an XP sp2
I'm running Sunbelt Kerio Personal Firewall 4.3.268.0
