XP SP2 firewall independently configure
Apr 06, 2005 1 Replies
I have 2 lan cards in my PC. Could I just use XP firewall for just one lan card in XP with SP2? I found that if I turn on firewall in XP, it takes effect on all lan card.
Thanks!
You can, in control panel open Windows Firewall configuration in Advanced you´ll find a list of adapters that you have in your computer, just uncheck that one that you don´t want the firewall on.
Best regards,
Khalil
