Cisco Pix 501 Newbie Problem
May 24, 2005 2 Replies
Hello,
I'm having a heck of a time accessing the start.html page after having successfully changed the default IP address of my Cisco PIX 501. Http, dhcpd and dhcpd address range are changed to reflect the new IP change as well. This was accomplished through the CLI via the serial terminal.
I can connect the DSL, server and 35 clients and all can acces the internet and receive mail
I just can't get back to the unit through a WEB interface after the change. With the default settings, I would enter https://192.168.1.1/start.html and I would connect. Now with an IP address of 10.0.0.1 I can't access by way of https://10.0.0.1/start.html I can't even ping 10.0.0.1
What step or missing command am I missing here? I would like to get a better understanding of the gui interface as well as the CLI and I want to check out the VPN configuration through the WEB interface.
Any suggestions, further info needed, other newsgroup suggestions?
Thank You In Advance,
Buck
_______________________________________________________________________________ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 -
The Worlds Uncensored News Source
In article , Buck Rogers wrote: :I'm having a heck of a time accessing the start.html page after having :successfully changed the default IP address of my Cisco PIX 501.
For PIX questions, it is often better to post to comp.dcom.sys.cisco
:I just can't get back to the unit through a WEB interface after the :change. With the default settings, I would enter :https://192.168.1.1/start.html and I would connect. Now with an IP :address of 10.0.0.1 I can't access by way of
:What step or missing command am I missing here?
The 'http' and 'pdm' and 'icmp' commands probably still refer to
192.168.1 .
Walter,
Thanks for the fast and helpful input! Greatly appreciated.
Regards,
Buck
