PIX 501 Config Issue
May 31, 2005 5 Replies
Jump to replies (5)
Hello,
I've been trying to solve this problem for a while now and can't seem to get a handle on it. I posted a question here last week with one response that didn't solve the problem (from Walter Roberson) and I thought I'd ask in a different way.
When I power up the pix, I can access the web configuration by typing https://192.168.1.1/startup.html. I can also access the pix via the serial terminal.
When I go in through the serial terminal and enter configure factory-default 10.0.0.1 255.255.0.0, and then write memory and then reload, I can't access the web interface by entering https://10.0.0.1/startup.html. I can still access via serial terminal. I can't figure out what I'm doing (or not doing) to keep me from accessing the web interface when the default is 10.0.0.1 One other note, when the default is 192.168.1.1 I can ping the pix and the pix can ping my computer. However, when I change the default to
10.0.0.1, I can't ping at all either way.
My config file follows:
: Saved : PIX Version 6.3(4) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password xxxxxxxxxxxx encrypted passwd xxxxxxxxxxxx encrypted hostname pixfirewall domain-name ciscopix.com fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside xxx.xxx.56.29 255.255.255.252 ip address inside 10.0.0.1 255.255.0.0 ip audit info action alarm ip audit attack action alarm pdm location 10.0.0.0 255.255.0.0 inside pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 route outside 0.0.0.0 0.0.0.0 xxx.xxx.56.30 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00 timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 10.0.0.0 255.255.0.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable telnet timeout 5 ssh timeout 5 console timeout 0 dhcpd address 10.0.0.2-10.0.0.129 inside dhcpd dns xxx.xxx.98.98 xxx.xxx.42.42 dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside dhcpd enable inside terminal width 80 Cryptochecksum:871652e553896e43834a961f76223a7e : end [OK]
Any input on how to accomplish accessing the pix via the web interface with a default of 10.0.0.1 255.255.0.0 would be greatly appreciated.
Regards
Buck
_______________________________________________________________________________ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 -
The Worlds Uncensored News Source
What does the setup on the PC look like? ('ipconfig /all' will probably be enough assuming it's a modern Wintel box).
Paul,
Ipconfig follows. Thanks for your input. Hope you have some additional thoughts.
One note, I'm configuring the pix offline and connected only to my laptop until I can get to a point to bring it online with VPN. At present, when I bring online, the servers and all 35 clients can access the internet and retrieve their email. I need the GUI to help me better understand the VPN portion of the configuration, knowing that the terminal CLI is better over all.
Regards,
Buck
C:\Documents and Settings\xxx>ipconfig /all
Windows IP Configuration
Host Name . . . . . . . . . . . . : xxx Primary Dns Suffix . . . . . . . : mallard.local Node Type . . . . . . . . . . . . : Hybrid IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No DNS Suffix Search List. . . . . . : mallard.local
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : Broadcom 440x 10/100 Integrated Controller Physical Address. . . . . . . . . : 00-11-43-66-55-C1 Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 10.0.0.4 Subnet Mask . . . . . . . . . . . : 255.255.0.0 Default Gateway . . . . . . . . . : 10.0.0.1 DHCP Server . . . . . . . . . . . : 10.0.0.1 DNS Servers . . . . . . . . . . . : xxx.xxx.98.98 xxx.xxx.42.42 Lease Obtained. . . . . . . . . . : Tuesday, May 31, 2005
3:56:22 PM Lease Expires . . . . . . . . . . : Tuesday, May 31, 2005 4:56:22 PM
For what it's worth, when I want to erase all and start all over again and get back up and running quickly, I do a "erase mem" and then reload, go through the initial dialog on the console to set IP address, etc, and then I start PDM and use the wizard to setup the VPN. Done.
Replace "erase mem" with "wr erase". Sorry - I did not have access to a box until now.
My memory just arrived and I'm getting ready to upgrade to 7.0 on a 515E.
Superficially I can't see anything obviously wrong myself, do telnet or ssh work after the address change?
