Hello,
Thanks for all the input I've received so far.
After my last post, I did config factory-default, wr m, and reload. I then re-configured based on input received from Mr. Roberson here.
My intentions are as follows for my PIX501:
Allow 9 individuals VPN accessability (L2TP) from their homes to the internal network via cable modem.
Home -> Cable Modem -> Internet -> Work DSL -> Pix501 -> Work Server
I have configured the PIX via the PDM GUI's VPN Wizard to test one of the users as noted in the config file below. The individuals' home computer is WinXP. I have configured a new L2TP VPN connection via the internet on the home computer.
I have the following questions on the config file I've posted.
- Access-list inside crypto-map lists 10.0.10.16 255.255.255.240. Why? Gateway is 10.0.0.1 255.255.0.0. Same with access list outside?
- PDM location is the same IP and Subnet Mask as #1 above. Why?
- Does the confuguration seem resonable based on what I want to accomplish?
When I tried to connect to the office via the home computer, no luck. Received an error 678 Not responding. I can successfully ping the static IP address assigned to the outside IP address of the PIX.
Firewalls are off at home during this test. Computer connected directly to cable modem at home during test.
Any input to help me get on the right track would be appreciated.
I can post the Win VPN connection properties if needed.
PIX501 config follows: I have intentionally double spaced after any line wrap.
Building configuration... : Saved : PIX Version 6.3(4) interface ethernet0 auto interface ethernet1 100full nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password xxxxxxxx encrypted passwd xxxxxxxxxxx encrypted hostname pixfirewall domain-name xxxxxx fixup protocol dns maximum-length 512 fixup protocol ftp 21 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol http 80 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol sip 5060 fixup protocol sip udp 5060 fixup protocol skinny 2000 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol tftp 69 names access-list inside_outbound_nat0_acl permit ip any 10.0.10.16
255.255.255.240
access-list outside_cryptomap_dyn_20 permit ip any 10.0.10.16
255.255.255.240
pager lines 24 mtu outside 1500 mtu inside 1500 ip address outside xxx.xxx.xxx.29 255.255.255.252 ip address inside 10.0.0.1 255.255.0.0 ip audit info action alarm ip audit attack action alarm ip local pool xxxxxx 10.0.10.20-10.0.10.29 pdm location 10.0.10.16 255.255.255.240 outside pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list inside_outbound_nat0_acl nat (inside) 1 0.0.0.0 0.0.0.0 0 0 route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.30 1 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225
1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server TACACS+ max-failed-attempts 3 aaa-server TACACS+ deadtime 10 aaa-server RADIUS protocol radius aaa-server RADIUS max-failed-attempts 3 aaa-server RADIUS deadtime 10 aaa-server LOCAL protocol local http server enable http 10.0.0.0 255.255.0.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-l2tp crypto ipsec transform-set TRANS_ESP_3DES_MD5 esp-3des esp-md5-hmac crypto ipsec transform-set TRANS_ESP_3DES_MD5 mode transport crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20
crypto dynamic-map outside_dyn_map 20 set transform-set TRANS_ESP_3DES_MD5
crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map crypto map outside_map interface outside isakmp enable outside isakmp key ******** address 0.0.0.0 netmask 0.0.0.0 isakmp policy 20 authentication pre-share isakmp policy 20 encryption 3des isakmp policy 20 hash md5 isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 telnet timeout 5 ssh timeout 5 console timeout 0 vpdn group L2TP-VPDN-GROUP accept dialin l2tp vpdn group L2TP-VPDN-GROUP ppp authentication chap vpdn group L2TP-VPDN-GROUP client configuration address local xxxxx vpdn group L2TP-VPDN-GROUP client authentication local vpdn group L2TP-VPDN-GROUP l2tp tunnel hello 60 vpdn username xxxxx password ********* vpdn username xxxxx password ********* vpdn enable outside dhcpd address 10.0.0.2-10.0.0.129 inside dhcpd dns xxx.xxx.xxx.98 xxx.xxx.xxx.42 dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside dhcpd enable inside terminal width 80 Cryptochecksum:62012c50ba73f45724c25b8658e7af56 : end [OK] pixfirewall(config)#
Regards,
Buck
_______________________________________________________________________________ Posted Via Uncensored-News.Com - Accounts Starting At $6.95 -
