Help Pix 501 Newbie VPN
Mar 08, 2006 3 Replies
Jump to replies (3)
I have been struggling for 2 days to get this VPN working
Have Pix 501 setup on local network with no server Want to connect from XP unit remotely - hopefully using RDC to connect to various machines. Will use with the VPN Client 4.8 or MS VPN... External IP 10.0.0.x Internal Pix 192.168.1.1 VPN Pool
192.168.2.1-10
I can connect via pptp but cannot ping the PIX, VPN Client - I don't even connect, but have blown away the config so many times that it may not be correct.! If anyone has suggestions, please respond. I think I have just read the info enough times that it is no longer making sense.
Here is the config PIX Version 6.2(2) nameif ethernet0 outside security0 nameif ethernet1 inside security100 enable password 8Ry2YjIyt7RRXU24 encrypted passwd 2KFQnbNIdI.2KYOU encrypted hostname pixfirewall domain-name ciscopix.com fixup protocol ftp 21 fixup protocol http 80 fixup protocol h323 h225 1720 fixup protocol h323 ras 1718-1719 fixup protocol ils 389 fixup protocol rsh 514 fixup protocol rtsp 554 fixup protocol smtp 25 fixup protocol sqlnet 1521 fixup protocol sip 5060 fixup protocol skinny 2000 names access-list outside_cryptomap_dyn_20 deny ip any 192.168.2.0
255.255.255.240 pager lines 24 interface ethernet0 10baset interface ethernet1 10full mtu outside 1500 mtu inside 1500 ip address outside dhcp setroute ip address inside 192.168.1.1 255.255.255.0 ip audit info action alarm ip audit attack action alarm ip local pool VPNPOOL 192.168.2.1-192.168.2.10 pdm logging informational 100 pdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 0 0 timeout xlate 0:05:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h323
0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute aaa-server TACACS+ protocol tacacs+ aaa-server RADIUS protocol radius aaa-server LOCAL protocol local http server enable http 192.168.1.0 255.255.255.0 inside no snmp-server location no snmp-server contact snmp-server community public no snmp-server enable traps floodguard enable sysopt connection permit-ipsec sysopt connection permit-pptp no sysopt route dnat crypto ipsec transform-set ESP-DES-SHA esp-des esp-sha-hmac crypto dynamic-map outside_dyn_map 20 match address outside_cryptomap_dyn_20 crypto dynamic-map outside_dyn_map 20 set transform-set ESP-DES-SHA crypto map outside_map 65535 ipsec-isakmp dynamic outside_dyn_map crypto map outside_map interface outside isakmp enable outside isakmp policy 20 authentication pre-share isakmp policy 20 encryption des isakmp policy 20 hash sha isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 vpngroup VPNGROUP address-pool VPNPOOL vpngroup VPNGROUP dns-server 192.168.1.1 vpngroup VPNGROUP wins-server 192.168.1.1 vpngroup VPNGROUP idle-time 1800 vpngroup VPNGROUP password ******** telnet timeout 5 ssh timeout 5 vpdn group VPNPPTP accept dialin pptp vpdn group VPNPPTP ppp authentication pap vpdn group VPNPPTP ppp authentication chap vpdn group VPNPPTP client configuration address local VPNPOOL vpdn group VPNPPTP client configuration dns 192.168.1.1 vpdn group VPNPPTP client configuration wins 192.168.1.1 vpdn group VPNPPTP pptp echo 100 vpdn group VPNPPTP client authentication local vpdn username VPNREMOTE password ********* vpdn enable outside dhcpd address 192.168.1.2-192.168.1.33 inside dhcpd lease 3600 dhcpd ping_timeout 750 dhcpd auto_config outside dhcpd enable inside terminal width 80 Cryptochecksum:5ff522dc753d9fe7147781083658bcdb : end [OK]
Thanks Zander
  1. This won't fix your problem, but I would upgrade your pix to 6.3.(4) if you can. I've never owned a 501 so I don't know what it will take.
  1. Without seeing your network, I would start with your access list. You have your VPN group in 192.168.2.x. About that, you have a crypto map denying traffic to that network.
I can't really upgrade this unit at this time, but I can really just use the PPTP protocol to connect, but like I said - when I connect and authenticate - it just takes down the local pc internet as well as not being able to ping/use the remote pix network. Ideally, what I want to do is connect via the internet to the 501, then be able to RDC into other PC's on the network.
I will look at the crypto again.
Zander
