RJ-45 to RJ-45 Console Cable -- How to set up in Hyperterm?
Jun 12, 2006 2 Replies
A Sharp
OK, a serial converter came in the box and that solved my problem. But all of the other routers come with a console cable as I described above. Is the console cable RJ45 to RJ45 for remote management via the network?
Most 1601R's I've received have the RJ-45 to Serial 9 connectors, which are easy to set up in Hyperterm on Windows XP. How do you communicate via the console with the RJ-45 to RJ-45 cables they now supply?
Thanks.
You have it backwards. The RJ45 cable with the converter was the original packaging. The RJ45 with the DB9 attached at the other end has only been out a year or two.
Scott
