How to Make a Pix 501 Console Cable?
Jun 21, 2006 2 Replies
Most relevant reply
achilles_mj
Hi, PINS: DB-9 1,2,3,4, 5 ,6,7,8,9 RJ-45 n,3,6,7,5 & 4,2,8,1,n patch cable only it means: 1 and 9 from DB-9 are not connected pin 2 from DB-9 connected with 3 from RJ-45 pin 5 DB-9 is connected to two pins from RJ-45 5 & 4 Best regards
I have lost the original DB-9 to RJ-45 cable that I used for console connections. I already have standard patch and crossover cables, as well as a build-it-yourself DB-9 to RJ-45 adapter kit. However, the documentation that I've found on building these cables seems suited for a rolled ethernet cable, of which I do not have. Does anyone know the proper DB-9 to RJ-45 pinout when using either a patch or a crossover? If so, please let me know.
Thanks,
-Jay
jaylucasaustin.rr.com napisal(a):
PINS:
it means:
Best regards
Thanks Achilles,
That did it!!!
-Jay
