USB to RJ-45 console cable?
Apr 03, 2005 1 Replies
BradReeseCom
Hi Jay, Have you may find the Black Box Custom Cable and Adapter Wizards helpful: Brad Reese Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272=20 Website:
USB to RJ-45 console cable? open original image
Hi All,
I know have read numerous threads on Google goups and cannot come up with an answer on this one.
I have already read and seen that there are cables/adapters that go from USB to DB-9. That would allow you to connect your standard serial console cable as you normall would. I am trying to find a way to eliminate this.
I would like to buy/make a cable that will have a USB connector on one end and an RJ-45 on the other. I'm not sure if it is as easy as cutting off a connector on the usb and just terminating the RX/TX/GND like you can do with a serial cable (DB-9).
I know there may be some issues with going from USB to rs-232 signaling and I could always build some kind of breakout box in the middle.
Any thought?????
- Jay
Hi Jay,
Sincerely,
Brad Reese BradReese.Com=AE Cisco Resource Center Toll Free: 877-549-2680 International: 828-277-7272=20 Website:
