Problems with 1750 and ssh
Jun 12, 2006 1 Replies
Hi gents I have lots of 1700 for frame relay connections between different places. All of them were already configured.And they can be accessed by telnet. I've always thought ssh is more appropiate than telnet, so I tried to configure ssh on them:
I tried something like this : line 1 no exec login authentication default rotary 1 transport input ssh /// in transpor input doesn't appear ssh just telnet.
line 2 no exec login authentication default rotary 2 transport input ssh
So can any of you help me to configure ssh ? Here is my show version :
Cisco Internetwork Operating System Software IOS (tm) C1700 Software (C1700-Y-M), Version 12.2(15)T, RELEASE SOFTWARE (fc1) TAC Support:
Support:
Tue 11-Mar-03 13:34 by ccai Image text-base: 0x80008120, data-base: 0x8098E4A0
ROM: System Bootstrap, Version 12.2(7r)XM1, RELEASE SOFTWARE (fc1)
GREMIS-LAU uptime is 2 minutes System returned to ROM by reload System restarted at 21:11:49 GMT+1 Mon Apr 25 2005 System image file is "flash:c1700-y-mz.122-15.t.bin"
cisco 1721 (MPC860P) processor (revision 0x100) with 27885K/4883K bytes of memor y. Processor board ID FOC07231RT1 (206895401), with hardware revision 0000 MPC860P processor: part number 5, mask 2 Bridging software. X.25 software, Version 3.0.0.
1 FastEthernet/IEEE 802.3 interface(s)
2 Serial(sync/async) network interface(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
Your code isn't capable of doing SSH. You need to step up to a release with basic crypto support. You're currently running the basic "IP" featureset. You need to step up to a release with "IPSEC 3DES" such as "IP/ADSL PLUS IPSEC 3DES" which happens to be the first available featureset that adds SSH support. Look for the "k9" in the filename if you aren't sure.
J
