Re: USB to RJ-45 Console Cable?
Apr 08, 2005 0 Replies
I would like to buy/make a cable that will have a USB
> c> If by "RJ-45" you mean an 8-position modular connector
> wired to carry an Ethernet circuit, you'll need an
> adapter such as Planet Technology Corp. Model PT9500. I
> have two of these devices in service, connecting oldish
> PCs (W98) to a L> RJ-45 connectors are also commonly used for all sorts of
> serial links -- including async (using RS-232 levels),
> sync (often RS-422), and even telecom (such as DS-1).
> It's not just Ethernet.
JXM2119 didn't tell us what kind signal s/he's using. I inferred Ethernet from the context of the question; if s/he has some other signal in mind, perhaps s/he should let us know.
I agree that 8-position modular connectors can be wired for things other than Ethernet; that's why my response to the original question began with the word "if." But I don't agree with the use of the term "RJ-45" to identify a connector. RJ45 is a USOC (albeit apparently obsolete); not a connector.
Neal McLain
