Reset Supervisor Engine 720 to factory defaults ??
Nov 21, 2005 2 Replies
CiscoHeadsetAdapter.com
Tobias, You can just erase startup config and reboot the card. It will bring the card to the "factory default" state. If you have a card in "hybrid" mode, you need to remove the main startup config (in this mode you have one interface to both, switch and router functionality).…
Hello,
how do i reset a Supervisor Engine 720 to the factory defaults ?
Thank you very much in advance, Tobias
Tobias,
If you have a card in "hybrid" mode, you need to remove the main startup config (in this mode you have one interface to both, switch and router functionality). If you have a card in the Native mode, then you have to remove configs in both modes - in the router and in the switch.
Good luck,
Mike
Thanks Mike
Have a nice day, Tobias
