How To Reset A Westell Modem To Factory Defaults?
Mar 01, 2005 2 Replies
diesel
Theres a lil white reset butten just next to where the ehtenet cable plugs in , press and hold for no longer then 30 sec , then logg into the modem config page ONLY after the dsl light has gone steady. the defualt username is admin and the default password is password. it…
I went to the address of my modem eg. xxx.xxx.x.x and logged in and changed something. Now I can't get into that address for some reason to change it back. Is there a way to reset factory defaults?
Thank-you
Isn't there a reset button? (might need a bent paper clip to access it)
Theres a lil white reset butten just next to where the ehtenet cable plugs in , press and hold for no longer then 30 sec , then logg into the modem config page ONLY after the dsl light has gone steady. the defualt username is admin and the default password is password. it should then ask you to change the defaults . do so.
