Errors in routers traffic?
Oct 08, 2005 5 Replies
Jump to replies (5)
Errors in routers traffic? open original image
I have a Cisco 7204VXR router, I noticed that when I'm using port:community@routerIP to get traffic on routers interfaces on MRTG, I noticed that the interfaces changed when I reboot the router. How can correct this?
You mean ifindex changed? You can use snmp-server ifindex persist command.
You can use ifname with MRTG, this is much better way. Example "FastEthernet
0/1".
