Dialer interfaces and MRTG.
Oct 05, 2006 4 Replies
Jump to replies (4)
I know that is a MRTG issue but
does anybody know how to get MRTG work with dialer interfaces on a Cisco router? Even downloading at the full speed it reports 0% of use. MRTG works fine on Ethernet 0. Where I'm wrong?
TIA
Alex.
I am not exactly sure but MRTG may be getting the interface "bandwidth" from the device. If so you may be able to fix it with
int dialer1 bandwidth xxx
Of course the ADSL interface has different upstream and downstream and there is only one interface bandwidth that you can set.
This is certainly the case with the x/255 interface rate counters
#sh int d1 Dialer1 is up, line protocol is up (spoofing) Hardware is Unknown Description: Internet address is 8 MTU 1500 bytes, BW 512 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 30 second input rate 1000 bits/sec, 1 packets/sec 30 second output rate 1000 bits/sec, 1 packets/sec
#sh run int d1 interface Dialer1 description bandwidth 512
#sh run int d1 interface Dialer1 description bandwidth 10 ! < -- Changed to 10
#sh int d1 Dialer1 is up, line protocol is up (spoofing) Hardware is Unknown Description: Internet address is 8 MTU 1500 bytes, BW 10 Kbit, DLY 20000 usec, reliability 255/255, txload 76/255, rxload 51/255
30 second input rate 2000 bits/sec, 2 packets/sec 30 second output rate 3000 bits/sec, 2 packets/sec
Hope that helps.
[in PPPOx context] I monitor with MRTG the Virtual-Access Interface x bounded to the dialer y, instead of dialer y (don't work).
  • sh interfaces dialer y indicate the vi bounded to it
  • sh snmp mib ifmib ifindex indicate the OID suffix of this vi
It works well.
Regards,
The 'bandwidth' command is only used for routing metrics.
This is not the case as is illustrated in detail in my previous post. It affects the output of the sh int command in the tx load and rx load sections.
It also is used for QoS configuration. I am certain that when configuring priority queuing that the queuing bandwidth configured is referenced to the configured "interface bandwidth"
IIRC the standard interfaces MIB can return a "bandwidth" I guessing here but I suppose that this value will be influenced by the configured "interface bandwidth".
There may be other uses too.
