cs mars logging
Apr 06, 2007 2 Replies
hi i need help I implementing some cisco switches for cs mars so i am confuse about logging
logging source-interface ? // what i need to put here i have 24 port on switch or did i need this and what is meead logging source-interface
logging trap debuging logging 192.168.0.10 (cs mars ip)
if your switch is just working as a layer 2 box, you can only set one Ip address for all switch access and management, with layer 3 features, you have a lot more options - define a separate, protected management net - tell management protocols, logging ..., to use an Ip from the protected net - here you need to set source interfaces
Hans
hi tnx man a lot can you tell me if you or sombari else work with cs mars why when i get incident always get source 0.0.0.0/0 and destination is ok i get full ip 192.168.0.10 ???
