been trying for a rediculously long time now to get a Cisco 837 (purchased in the UK) to work with French Telecoms. Onsite user states the line has worked fine with his FT supplied modem for months.
FT state:
VPI =8
VCI 35 = 35
Type d'encapsulation =VXMUX
Protocole = PPPoA/PPPoE
I have tried every combination of pap/chap/encapsulation/dsl operating-mode i can think of with no success.
I am using the standard Dialer1 and ATM0 interfaces and will post config if required.
I am really just curious if anyone has a working config for this device.
Hi,I have been trying to configure multiple dialers to connect from a Single PVC...
M
markcram
L
Laurent
In fact there is no problem you can use the "lavander" cable shipped in the box because we use ADSL Filters with "French SRTE" connector on one side and a RJ11 on the other side.
I have a CISCO 857W and it works fine in France with Wanadoo/Orange ISP.
Here is my current working conf (857W is wifi enabled).
Building configuration...
Current configuration : 8109 bytes ! version 12.4 no service pad service timestamps debug datetime msec service timestamps log datetime msec service password-encryption ! hostname cisco857w_000 ! boot-start-marker boot system flash c850-advsecurityk9-mz.124-9.T1.bin boot-end-marker ! logging buffered 51200 debugging enable secret 5 ******** enable password 7 ******** ! no aaa new-model ! resource policy ! no ip source-route no ip dhcp use vrf connected ip dhcp excluded-address 192.168.1.0 192.168.1.99 ! ip dhcp pool dhcppool import all network 192.168.1.0 255.255.255.0 default-router 192.168.1.1 domain-name home.triplezero.net dns-server 192.168.1.1 ! ! ip cef ip domain name home.triplezero.net ! !
username cisco password 7 ******** ! ! ! bridge irb ! ! ! interface ATM0 no ip address ip virtual-reassembly no ip mroute-cache no atm ilmi-keepalive pvc 8/35 encapsulation aal5mux ppp dialer dialer pool-member 1 ! dsl operating-mode auto ! interface FastEthernet0 ! interface FastEthernet1 ! interface FastEthernet2 ! interface FastEthernet3 ! interface Dot11Radio0 no ip address no ip redirects ip local-proxy-arp ! encryption mode ciphers tkip ! ssid private.triplezero.net authentication open authentication key-management wpa guest-mode wpa-psk ascii 7 ******** ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0
48.0 54.0 channel 2422 station-role root no dot11 extension aironet no cdp enable bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Vlan1 no ip address ip nat inside ip virtual-reassembly bridge-group 1 bridge-group 1 spanning-disabled ! interface Dialer0 ip address negotiated ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 dialer-group 1 ppp authentication chap callin ppp chap hostname fti/******* ppp chap password 7 ******** ppp ipcp dns request ! interface BVI1 ip address 192.168.1.1 255.255.255.0 ip nat inside ip virtual-reassembly ! ip route 0.0.0.0 0.0.0.0 Dialer0 ! no ip http server ip http secure-server ip dns view ezvpn-internal-view domain name-server 192.168.12.181 ip dns server ip nat inside source list 1 interface Dialer0 overload !
dialer-list 1 protocol ip permit snmp-server community ******** RO ! control-plane ! bridge 1 route ip ! line con 0 no modem enable line aux 0 line vty 0 4 privilege level 15 password 7 ******** login local transport input telnet ssh ! scheduler max-task-time 5000 end
snipped-for-privacy@gmail.com wrote in news:1161616323.991528.306570 @m73g2000cwd.googlegroups.com:
W
www.BradReese.Com
You may wish to investigate the Cisco 837 Config Wizard:
as well as the Cisco 837 IPv6 Config Wizard:
Hope this helps.
B
Bod43
I have put an 877 in france too.
I agree with the above config.
One thing though that I checked on is that the "phone" line was not ISDN since I have heard that ISDN is used in some cases for domestic lines in France.
The French, as is their custom, use their own term for ISDN, namely RNIS (IIRC) which is as you might expect an acronym representing a translation of Integrated Services Digital Network.
This one was also on Orange (ex Wanadoo).
Config fragment:
interface ATM0 description ADSL Connection to Internet no ip address load-interval 30 no atm ilmi-keepalive pvc 8/35 pppoe-client dial-pool-number 1 ! dsl operating-mode auto
interface Dialer1 bandwidth 512 ip address negotiated ip nat outside encapsulation ppp dialer pool 1 dialer-group 1 ppp authentication pap chap callin ppp chap hostname a-hostname ppp chap password a-password
M
markcram
Thanks for all your support guys.
I am still getting ATM0 down down in "show ip int brief" which still appears to be a cable issue to me.
I have the user connected with the supplied purple cable and after some translation issues it seems that the carier detect light isnt illuminated.
Will call FT/Orange today again to confirm that it is indeed ADSL and not ISDN
Mark
snipped-for-privacy@hotmail.co.uk wrote:
M
Mark
User now explains he has ADSL2, which Cisco website states is not supported by the 837.
Bad luck for him, still thought i'd get some sort of ATM signal.
Thanks aga> Thanks for all your support guys.
Report Content
ASAP.
