Cisco 837 - MRTG - monitoring SNR?
May 07, 2006 6 Replies
Kelvin J. Hill
Local Attn. .1.3.6.1.2.1.10.94.1.1.3.1.5.14 Remote Attn. .1.3.6.1.2.1.10.94.1.1.2.1.5.14 Local SNR. .1.3.6.1.2.1.10.94.1.1.3.1.4.14 Remote SNR. .1.3.6.1.2.1.10.94.1.1.2.1.4.14 Hope this helps. Kelvin. * Posted via a free Usenet account from *
Hi all,
On the Cisco 837, is it possible to monitor SNR via an OID, using MRTG? I can't find an OID which a) looks like it will work, and b) does work!
All help appreciated.
Jim
Hope this helps.
Kelvin.
*** Posted via a free Usenet account from
Hi Kelvin, that's fabulous, than you! These work perfectly.
If you don't mind, can you tell me what I'm doing wrong? I've run:
snmpwalk -c public -v 1 192.168.1.1
but the numbers you listed do not appear aywhere in the walk. Any idea where I'm going wrong? I shall probably want to monitor more values in the future, so I'd like to be able to find them myself if I can.
Thanks again,
Jim
This doesn't work for me (on cisco 877W)
any idea ?
Here's my entire mrtg.cfg file for my Cisco 837 for MRTG. Note the "/
10" to scale the att and snr values.
Jim
EnableIPv6: no WorkDir: /var/www/admin/mrtg
Target[cpu]:1.3.6.1.4.1.9.2.1.58.0&1.3.6.1.4.1.9.2.1.58.0:public@192.168.1.1 YLegend[cpu]: Cisco 837 - CPU Utilisation ShortLegend[cpu]: % MaxBytes[cpu]: 100 Options[cpu]: nopercent, gauge, unknaszero, growright Unscaled[cpu]: dwmy Legend1[cpu]: Cisco 837 - CPU Utilisation Legend2[cpu]: . Legend3[cpu]: Max value per interval on graph Legend4[cpu]: . LegendI[cpu]: CPU: LegendO[cpu]: . Title[cpu]: cpu PageTop[cpu]: cpu Colours[cpu]: GREEN#00eb0c,BLUE#0000ff,GRAY#AAAAAA,VIOLET#ff00ff WithPeak[cpu]: ymw
Target[memory]:1.3.6.1.4.1.9.9.48.1.1.1.5.1&1.3.6.1.4.1.9.9.48.1.1.1.6.1:public@192.168.1.1 MaxBytes[memory]: 16384000 Unscaled[memory]: dwmy Title[memory]: Cisco 837 - Memory PageTop[memory]: Cisco 837 - Memory Options[memory]: gauge, nopercent, unknaszero, growright YLegend[memory]: Bytes ShortLegend[memory]: Bytes Legend1[memory]: Used Legend2[memory]: Free Legend3[memory]: Max value per interval on graph Legend4[memory]: . LegendI[memory]: Used LegendO[memory]: Free Colours[memory]: GREEN#00eb0c,BLUE#0000ff,GRAY#AAAAAA,VIOLET#ff00ff WithPeak[memory]: ymw
Target[atm0]: 1:public@192.168.1.1: SetEnv[atm0]: MRTG_INT_IP="" MRTG_INT_DESCR="ATM0" MaxBytes[atm0]: 64000 Unscaled[atm0]: dwmy Title[atm0]: Cisco 837 - ADSL Line (ATM 0) PageTop[atm0]: Cisco 837 - ATM0 Options[atm0]: growright
Target[eth0]: 2:public@192.168.1.1: SetEnv[eth0]: MRTG_INT_IP="" MRTG_INT_DESCR="Ethernet0" MaxBytes[eth0]: 1250000 Unscaled[eth0]: dwmy Title[eth0]: Cisco 837 - Ethernet (Eth 0) PageTop[eth0]: Cisco 837 - Ethernet Options[eth0]: growright
Target[snr]:.1.3.6.1.2.1.10.94.1.1.3.1.4.14&.1.3.6.1.2.1.10.94.1.1.2.1.4.14:public@192.168.1.1 / 10 Title[snr]: Cisco 837 - SNR Analysis Background[snr]: #ffffff PageTop[snr]: Cisco 837 - SNR Analysis WithPeak[snr]: wmy XSize[snr]: 500 YSize[snr]: 200 MaxBytes[snr]: 200000 Options[snr]: gauge, growright, nopercent YLegend[snr]: SNR Value ShortLegend[snr]: SNR Legend1[snr]: Average Legend2[snr]: Legend3[snr]: Maximum Legend4[snr]: LegendI[snr]:  Local SNR: LegendO[snr]:  Remote SNR:
Target[att]:.1.3.6.1.2.1.10.94.1.1.3.1.5.14&.1.3.6.1.2.1.10.94.1.1.2.1.5.14:public@192.168.1.1 / 10 Title[att]: Cisco 37 - Line Attentuation Background[att]: #ffffff PageTop[att]: Cisco 837 - Line Attentuation WithPeak[att]: wmy XSize[att]: 500 YSize[att]: 200 MaxBytes[att]: 200000 Options[att]: gauge, growright, nopercent YLegend[att]: Att. Value ShortLegend[att]:  Attenuation Legend1[att]: Average Legend2[att]: Legend3[att]: Maximum Legend4[att]: LegendI[att]:  Local Att.: LegendO[att]: %nbsp;Remote Att.:
I think you may have to use the correct option string for snmpwalk to show you numbers rather than names.
snmpwalk -c public -v 1 -On 192.168.1.1
This works for me on my C837.
Regards, Kelv.
SNMP Error: Received SNMP response with error code error status: noSuchName index 1 (OID: 1.3.6.1.2.1.10.94.1.1.3.1.4.14) SNMPv1_Session (remote host: "x.x.x.x" [x.x.x.x].161) community: "---------" request ID: 401085688 PDU bufsize: 8000 bytes timeout: 2s retries: 5 backoff: 1) at /usr/local/lib/perl5/site_perl/5.8.2/SNMP_util.pm line 458 SNMPGET Problem for .1.3.6.1.2.1.10.94.1.1.3.1.4.14 .1.3.6.1.2.1.10.94.1.1.2.1.4.14 sysUptime sysName on ----------@x.x.x.x at /usr/local/bin/mrtg line 1620 WARNING: skipping because at least the query for .1.3.6.1.2.1.10.94.1.1.3.1.4.14 on x.x.x.x did not succeed ERROR: Target[x.x.x.x.snr][_IN_] ' $$target[26]{$mode} / 10' (warn): Use of uninitialized value in division (/) at (eval 85691) line 1. ERROR: Target[x.x.x.x.snr][_OUT_] ' $$target[26]{$mode} / 10' (warn): Use of uninitialized value in division (/) at (eval 85692) line 1. WARNING: Skipping Update of x.x.x.x.snr, inlast is not defined WARNING: Skipping Update of x.x.x.x.snr, outlast is not defined
