Cisco 837 headache
May 12, 2006 4 Replies
Jump to replies (4)
Will the Cisco 837 work OK in the UK with BT broadband?
Mine keeps complaining that the DNS servers are invalid, even if I input them manually?
Adrian
post the IOS version in use, your current config and the entire session where you try to apply the dns server commands
I'm not using it with BT, but I'm happily using a Cisco 837 with Eclipse Internet (which is also PPPoA).
If you don't get any joy thenI can share my config with you.
Cheers,
Jim
Thankyou.
I'm using CRWS to set the router up.
Router Model : C837
IOS Image Name : c837-k9o3y6-mz.123-4.T7.bin
IOS Version :
12.3(4)T7
Current configuration : 2347 bytes
version 12.3
no service pad
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname huckle
boot-start-marker
boot-end-marker
no logging buffered
no logging console
enable secret 5 $1$ipJ5$vL/6kIhwMq/4A8vKtggWQ0
enable password hucky
username CRWS_Srini privilege 15 password 0 $1$W1fA$o1oSEpa2131764179
username CRWS_Kannan privilege 15 password 0 $1$W1fA$o1oSEpa1782032486
username CRWS_Ritesh privilege 15 password 0 $1$W1fA$o1oSEpa115430558
username CRWS_Santhosh privilege 15 password 0 $1$W1fA$o1oSEpa1694627869
no aaa new-model
ip subnet-zero
no ip routing
ip name-server 194.72.9.38
ip name-server 62.6.40.162
ip dhcp excluded-address 192.168.0.1
ip dhcp pool CLIENT
import all
network 192.168.0.0 255.255.255.0
default-router 192.168.0.1
lease 0 2
ip audit notify log
ip audit po max-events 100
ip ssh break-string
no ftp-server write-enable
no crypto isakmp enable
interface Ethernet0
ip address 192.168.0.1 255.255.255.0
ip nat inside
no ip route-cache
ip tcp adjust-mss 1452
no ip mroute-cache
hold-queue 100 out
interface ATM0
no ip address
no ip route-cache
no ip mroute-cache
atm vc-per-vp 64
no atm ilmi-keepalive
pvc 0/38
oam-pvc 0
encapsulation aal5mux ppp dialer
dialer pool-member 1
dsl operating-mode auto
interface Dialer1
ip address negotiated
ip mtu 1458
ip nat outside
encapsulation ppp
dialer pool 1
dialer remote-name redback
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname snipped-for-privacy@btinternet.com
ppp chap password 0 ********
ppp pap sent-username snipped-for-privacy@btinternet.com password 0 ********
ppp ipcp dns request
ppp ipcp wins request
hold-queue 224 in
ip nat inside source list 102 interface Dialer1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Dialer1
ip http server
no ip http secure-server
access-list 102 permit ip 192.168.0.0 0.0.0.255 any
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
transport preferred all
transport output all
line aux 0
line vty 0 4
exec-timeout 120 0
password hucky
login local
length 0
transport input all
scheduler max-task-time 5000
end
Since posting this i've managed to solve the problem. I didn't have IP routing enabled. ooops!
Thanks for your help anyway
