only 29k for configuration memory
Jun 27, 2006 1 Replies
We have an aging 3620 chassis that only has 29k of config mem (sh ver below), I have had to compress the config to store the config but I hope this is a temp solution.
Is there a way to extend the memory for the config??
**************************************************************************************** Cisco Internetwork Operating System Software IOS (tm) 3600 Software (C3620-D-M), Version 11.2(16)P, RELEASE SOFTWARE (fc1) Copyright (c) 1986-1998 by cisco Systems, Inc. Compiled Mon 19-Oct-98 13:12 by pwade Image text-base: 0x600088E0, data-base: 0x6058A000
ROM: System Bootstrap, Version 11.1(17)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc
2)
War3620 uptime is 5 minutes System restarted by reload System image file is "flash:c362011216.bin", booted via flash
cisco 3620 (R4700) processor (revision 0x81) with 18432K/6144K bytes of memory. Processor board ID 07658220 R4700 processor, Implementation 33, Revision 1.0 Bridging software. X.25 software, Version 2.0, NET2, BFE and GOSIP compliant.
4 Ethernet/IEEE 802.3 interface(s)
4 Serial network interface(s) DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
4096K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
Caveat:- I have forgotten everything I ever knew about 11.2(16)P.
I would doubt that it could be changed.
I don't see any difficulty with having the config compressed and this is the default for many modern platforms.
If compression is insufficient then at least in some platforms you can put the config on Flash (tftp too?).
Check the boot system commands. Beware though that when I last looked at it copy run start still wrote the config to nvram and not to the configured file. You needed to do
copy run flash:my-config-file
