Point-to-point T1 with 2620XM and crossover cable
Apr 25, 2006 11 Replies
Jump to replies (11)
I'm new to T1s, as I'm from a country where they don't exist. I'm trying to get a test network up between two 2620XMs with single-port T1 CSU/DSU WICs, installed in slot0 of each router. Both 2620s are running IOS 12.2(34). Unfortunately, "sh int" reports that ser0/0 on each router is down, thus obviously I'm not getting a connection. I'm using a T1 crossover cable (wire 1>5, 2>4 I believe) and, when it's connected, the "AL" and "CD" lights on the WICs on each router are lit.
Here are the configs:
router1: ! version 12.2 ! hostname test1 ! ip subnet-zero ! interface FastEthernet0/0 no ip address shutdown duplex auto speed auto ! interface Serial0/0 ip address 192.168.0.1 255.255.0.0 service-module t1 timeslots 1-24 ! ip classless no ip http server ! ! line con 0 line aux 0 line vty 0 4 ! end
router2: ! version 12.2 ! ip subnet-zero ip cef ! interface FastEthernet0/0 no ip address shutdown speed auto half-duplex ! interface Serial0/0 ip address 192.168.1.1 255.255.0.0 no fair-queue service-module t1 timeslots 1-24 ! ip classless ip http server ! dialer-list 1 protocol ip permit ! line con 0 line aux 0 line vty 0 4 password *** login ! end
Here is the interface detail:
router1: Serial0/0 is down, line protocol is down Hardware is PQUICC with Fractional T1 CSU/DSU Internet address is 192.168.0.1/16 MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation HDLC, loopback not set Keepalive set (10 sec) Last input 00:24:04, output 00:24:06, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/1/256 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 1152 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 4 packets input, 846 bytes, 0 no buffer Received 4 broadcasts, 0 runts, 1 giants, 0 throttles 1 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 1 packets output, 24 bytes, 0 underruns 0 output errors, 0 collisions, 48 interface resets 0 output buffer failures, 0 output buffers swapped out 2 carrier transitions DCD=down DSR=up DTR=up RTS=up CTS=down
router2: Serial0/0 is down, line protocol is down Hardware is PQUICC with Fractional T1 CSU/DSU Internet address is 192.168.1.1/16 MTU 1500 bytes, BW 1536 Kbit, DLY 20000 usec, reliability 252/255, txload 1/255, rxload 1/255 Encapsulation HDLC, loopback not set Keepalive set (10 sec) Last input 00:24:36, output 00:24:33, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 1 packets input, 24 bytes, 0 no buffer Received 1 broadcasts, 0 runts, 0 giants, 0 throttles 1628 input errors, 769 CRC, 825 frame, 0 overrun, 0 ignored, 33 abort 4 packets output, 846 bytes, 0 underruns 0 output errors, 0 collisions, 53 interface resets 0 output buffer failures, 0 output buffers swapped out 2 carrier transitions DCD=down DSR=up DTR=up RTS=up CTS=down
Any help would be greatly appreciated!
TIA and HAND,
Chris
T1 is a synchronous tramsmission facility and so the "circuit" has to be timed. On a real T1 the circuit would be timed by the carrier and the router's built in DSU would synch to networkk time. in a back to bak scenario you need to provide this timing. This is done by having one of the router clock your "ciurcuit"
Use the "show controller t1" command to find out the controller designation on your router
controller t1 clock source internal
I knew that there had to be one clock source, and I entered that in the ser0/0 interface with the command "clock rate 56000". Strangely, though, it doesn't seem to show up in the output from "show running" or "show int ser0/0". I'm not sure why that is?
I'm at home now so I can't run the command you mentioned just yet, but I'll run it tomorrow morning & post the results.
TIA!
The clock rate command is used when there is a V.35 interface but not when you have a bulit-in DSU
V.35 as in if I was really using a serial cable, right? But when I'm using a T1 crossover cable the router uses it's internal DSU?
"show controller t1" shows nothing on both routers, i.e. I run the command and it doesn't give me any output; and then returns to the enable prompt.
Do I need the "service-module t1 clock source internal" command on one router, or both? I'm still having the same problems, AL and CD lights are illuminated on the WICs but Serial0/0 is still down on both routers.
Internal clocking is just done on one router; other routerwill derive clock
I think I have it up and running now, thanks! I can ping Serial0/0 on each router from the other router, without Ethernet connections plugged in.
Interestingly, "show controller T1" still does not give me any output...
"show controller t1" works with other integrated CSU/DSUs, like the VWICs. Use "show service-module s0/0" for yours.
Also keep in mind that the default timeslot size for some T1 controllers is 56kbps. That took me about 30 minutes to figure out will installing one! You set the timeslot size with
service-module t1 timeslots 1-24 speed 64
Although you've probably figured it out, one side needs to provide the clocking, and the other side receives clocking from the line.
To configure one side to provide clocking, use
service-module t1 clock source internal.
The default is to receive clocking from the line.
Great, thanks Mark! That "show service-module" command worked a treat, it gives me good information. One problem is that I didn't do a good job of crimping the crossover cable, it's easily to knock out which causes CD errors. So, I'll re-do that.
I actually used "service-module t1 timeslots all"; and according to "show service-module" it's using all 24 channels @ 64K to give me
1536K, which seems right to me. But thanks for the heads-up!
Chris
Chris
If you are having problems with the wires not crimping in tight then you might want to check to see if you have the correct type of RJ-45 end. They come in two flavors, solid wire ends and stranded wire ends. If you look from the side of the connector and the part of the pins that contacts the wires inside is just pointed or kind of "U" shaped then it is probably for stranded wire, the type used for patch cables. If however, they have two slits or thus three fingers then they are for probably for solid wire, the type used for punch down blocks or for runs between the wiring closet, through the walls and eventually to the jack. Using one type of connector for the other type of wire will usually test the limits of your CRC counter. I tried to find a web link that shows pictures of the different types of connectors but all I could come up with was sites that talked about them and would not show them. Here is one...
Hope this helps you keep your CRC's down.
