problem enabling ISL on 3620
Jul 18, 2005 1 Replies
Hi, I have a Cisco 3620 and trying to enable ISL encap on that (VLAN communication). but it seems there is no such command available on this router. Can someone help me to do this. Thanks in advance-Rob
sho ver Cisco Internetwork Operating System Software IOS (tm) 3600 Software (C3620-I-M), Version 12.0(28c), RELEASE SOFTWARE (fc1) Copyright (c) 1986-2005 by cisco Systems, Inc. Compiled Wed 30-Mar-05 15:32 by pwade Image text-base: 0x60008918, data-base: 0x6066E000
ROM: System Bootstrap, Version 11.1(7)AX [kuong (7)AX], EARLY DEPLOYMENT RELEASE SOFTWARE (fc2)
county uptime is 2 hours, 46 minutes System restarted by power-on System image file is "flash:c3620-i-mz.120-28c.bin"
cisco 3620 (R4700) processor (revision 0x81) with 12288K/4096K bytes of memory. Processor board ID 05970422 R4700 processor, Implementation 33, Revision 1.0 Bridging software. X.25 software, Version 3.0.0.
2 FastEthernet/IEEE 802.3 interface(s) DRAM configuration is 32 bits wide with parity disabled.
29K bytes of non-volatile configuration memory.
4096K bytes of processor board System flash (Read/Write)
Configuration register is 0x2102
Your version of software doesn't support it. The feature sets in release
12.0(28c) that do support it are:
ENTERPRISE PLUS c3620-js-mz.12.0-28c ENTERPRISE PLUS IPSEC 56 c3620-js56i-mz.12.0-28c ENTERPRISE/APPN PLUS c3620-ajs-mz.12.0-28c ENTERPRISE/APPN PLUS IPSEC 56 c3620-ajs56i-mz.12.0-28c IP PLUS c3620-is-mz.12.0-28c IP PLUS 40 c3620-is40-mz.12.0-28c IP PLUS IPSEC 56 c3620-is56i-mz.12.0-28c IP/IPX/AT/DEC c3620-d-mz.12.0-28c IP/IPX/AT/DEC PLUS c3620-ds-mz.12.0-28c
Regards,
Martin
