BGP cisco 6500
Mar 20, 2009 1 Replies
BGP cisco 6500 open original image
Hi, I have problem with BGP I cant set AS number my AS look like 3.XX
Router(config)#router bgp 3.xx ^ % Invalid input detected at '^' marker.
Thanks for help
You require support for 32-bit ASNs (search for BGP Support for 4-byte ASNs in Feature Navigator). This has just been introduced into 12.4(24)T for ISRs (2800/3800-series) and the 7200-NPE-G2, but not yet in any
6500-series code e.g. SXI, as far as I am aware.
I believe RIPE are now issuing 32-bit ASNs (as of January 2009) unless a
16-bit ASN is specifically requested.
Cheers,
Matt
