saving configuration
Nov 14, 2005 2 Replies
Hi, I have remote access through reverse telnet to some lab and one problem occurs. When I'm trying to execute command 'copy start run' the following error appears:
copy start run Destination filename [running-config]?
ip ssh break-string ^ % Invalid input detected at '^' marker.
Do anyone know what is a problem? Maybe I have no permission to use this command? Thanks for any help. Regards, Andrew
The start-up config was probably written with an IOS that supported ssh. Your current IOS appears not to support ssh. Did you downgrade IOS lately?
U¿ytkownik "Rex Johnson" napisa³ w wiadomo¶ci news:Jx0ef.7230$ snipped-for-privacy@newssvr30.news.prodigy.com...
I have only access to lab, but I will ask admin what is wrong - probably there could be even bug in the IOS. Thanks for help.
