Hi guys,
is a there a way to limit the bandwidth on a switch port? I don't want to do QoS just to restrict whatever flows through a port to a specific limit. The switch is Cisco 4006.
TIA
Alex.
Hi Alex, You may wish to investigate Storm Control: this helps. Brad Reese - Cisco Technical Forums Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant - Cisco Authorized…
Read the full replyHi guys,
TIA
Alex.
Hi Alex,
Brad Reese BradReese.Com - Cisco Technical Forums
Uhmmmm... it's for 2900/3500 series.....
Anyway I can set the limit in packets per seconds. So keeping the maximum size of a packet as 1500 bytes I need only to divide the bandwidth by that number*8, i.e. 12000.
Now I only need to find how to do that on a 4006.
Thanks, you gave me a good point from where to get started.
Alex.
Alex,
Cisco Catalyst 4000 Series Switch Documentation:
Brad Reese Global Cisco Systems Pre-Sales Support
