async connection to the router
Mar 27, 2006 1 Replies
Most relevant reply
Aaron Leonard
~ hello ~ i need know how, if at all is possible to connect to the router async, ~ after searching the groups, i understood that most off the serials are ~ sync. Yes, many routers have interfaces (lines) that support async connectivity. ~ an other thing, ~ i saw this commend…
async connection to the router open original image
hello i need know how, if at all is possible to connect to the router async, after searching the groups, i understood that most off the serials are sync.
an other thing, i saw this commend "transport input all" (in the interface config), what does it mean?
~ an other thing, ~ i saw this commend "transport input all" (in the interface config), ~ what does it mean?
"Transport input all" is a line (not interface) configuration command. It is documented in the command reference.
~ thanks :)
For further reading, I would recommend augmenting "searching the groups" with our website,
. Here are a few links in particular that might come in handy:
"Overview of Lines, Interfaces, and Controllers"
"Configuring a Terminal/Comm Server"
Cheers,
Aaron
