Hello all,
I am trying to configure an 1841 router with two internal modems for dialup and callback service, but for some reason my PC clients are getting error 619, which could be anything... Does somebody have a working sample configuration for such a scenario ? Here is what I have configure so far:
! version 12.3 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers ! hostname dialout_hme01 ! boot-start-marker boot-end-marker ! security authentication failure rate 3 log security passwords min-length 6 logging buffered 51200 debugging enable secret 5 $1$c5wE$VNUXfvq.fGezvyRmsgpVL0 ! no aaa new-model ! resource policy ! clock timezone PCTime 1 clock summer-time PCTime date Mar 30 2003 2:00 Oct 26 2003 3:00 mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 ip subnet-zero no ip source-route ip cef ! ! ip tcp synwait-time 10 no ip dhcp use vrf connected ip dhcp excluded-address 192.168.188.1 ip dhcp excluded-address 192.168.188.33 ip dhcp excluded-address 192.168.188.65 ! ip dhcp pool Async0/1/0 import all network 192.168.188.0 255.255.255.224 default-router 192.168.188.1 lease 0 4 ! ip dhcp pool Async0/1/1 import all network 192.168.188.32 255.255.255.224 default-router 192.168.188.33 lease 0 4 ! ip dhcp pool BRI0/0/0 import all network 192.168.188.64 255.255.255.224 default-router 192.168.188.65 lease 0 4 ! ! no ip bootp server ip domain name hme.com ip name-server 130.139.36.5 no ftp-server write-enable isdn switch-type basic-net3 ! username test password 7 03105E18125E731F ! ! ! interface Null0 no ip unreachables ! interface FastEthernet0/0 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE
0$$ES_LAN$$FW_INSIDE$ ip address 130.139.48.62 255.255.254.0 no ip redirects no ip unreachables no ip proxy-arp ip route-cache flow duplex auto speed auto no mop enabled ! interface FastEthernet0/1 no ip address no ip redirects no ip unreachables no ip proxy-arp ip route-cache flow shutdown duplex auto speed auto no mop enabled ! interface BRI0/0/0 description bri 0/0$FW_INSIDE$ ip address 192.168.188.65 255.255.255.224 no ip redirects no ip unreachables no ip proxy-arp encapsulation ppp ip route-cache flow dialer-group 1 isdn switch-type basic-net3 isdn point-to-point-setup no keepalive no fair-queue no cdp enable ppp callback accept ppp authentication pap ! interface Async0/1/0 description asyn 1/0 no ip address no ip redirects no ip unreachables no ip proxy-arp encapsulation ppp no ip route-cache cef no ip route-cache dialer pool 1 dialer in-band dialer pool-member 1 async mode dedicated ! interface Async0/1/1 description asyn 1/1 no ip address no ip redirects no ip unreachables no ip proxy-arp encapsulation ppp no ip route-cache cef no ip route-cache dialer pool 2 dialer in-band dialer pool-member 2 async mode dedicated ! interface Dialer1 ip address 192.168.188.1 255.255.255.224 encapsulation ppp no ip route-cache cef no ip route-cache dialer pool 1 dialer in-band dialer-group 1 no cdp enable ppp authentication pap ! interface Dialer2 ip address 192.168.188.33 255.255.255.224 encapsulation ppp no ip route-cache cef no ip route-cache dialer pool 2 dialer in-band dialer-group 1 no cdp enable ppp authentication pap ! ip classless ! ip http server ip http access-class 1 ip http authentication local ip http timeout-policy idle 600 life 86400 requests 10000 ! logging trap debugging access-list 1 permit 130.139.48.77 access-list 1 permit 161.89.62.10 dialer-list 1 protocol ip permit no cdp run ! control-plane ! banner login ^CAuthorized access only! Disconnect IMMEDIATELY if you are not an authorized user! ^C banner motd ^CACCESS PERMITED ONLY FOR AUTHORIZED PERSONS^C ! line con 0 access-class 1 in login local transport output telnet line aux 0 access-class 1 in login local transport output telnet line 0/1/0 0/1/1 login local modem InOut autoselect ppp stopbits 1 speed 115200 flowcontrol hardware line vty 0 4 access-class 1 in privilege level 15 login local transport input telnet transport output telnet line vty 5 15 access-class 1 in privilege level 15 login local transport input telnet transport output telnet ! scheduler allocate 4000 1000 ntp server 130.139.48.22 end
Pretty sure I am missing something here...thanks for your help in advance !
Regards,
Naz
