Trouble connecting to modem. Need some help.
Aug 04, 2006 8 Replies
Jump to replies (8)
Trouble connecting to modem. Need some help. open original image
Hello: I am new to working with Cisco products and I am trying to setup my 1760 router to make a dialup connection to my ISP with the WIC-1T serial card and an external V.92 modem. I realize it's an involved process and I am trying to read all the Cisco documents that relate to my situation. I'm taking it one step at a time. Right now I can't open a session to the modem to look at it's configuration (I'm doing this in hyperterminal in MS Windows with a console connection). Also I think I have properly put the Serial interface into async mode, but the Serial interface never seems to go into an up state. Slot 0 LED is on, CONN led on the card is on when the modem is on. Power and transmit LED's on the modem are on. There must be some configurations I have missed. Help would be appreciated. Below is some output. Thanks Bill
Router#telnet 192.10.0.3 2001 Trying 192.10.0.3, 2001 ... % Destination unreachable; gateway or host down Router#show line Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
  • 0 CTY - - - - - 0 4 0/0
- 1 TTY 115200/115200- inout - - - 0 0 0/0 Se0/0
5 AUX 9600/9600 - - - - - 0 0 0/0
- 6 VTY - - - - - 0 0 0/0
- 7 VTY - - - - - 0 0 0/0
- 8 VTY - - - - - 0 0 0/0
- 9 VTY - - - - - 0 0 0/0
- 10 VTY - - - - - 0 0 0/0
Line(s) not in async mode -or- with no hardware support:
2-4
Router#show line 1
Line 1, Location: "", Type: "" Length: 24 lines, Width: 80 columns Baud rate (TX/RX) is 115200/115200, no parity, 2 stopbits, 8 databits Status: No Exit Banner Capabilities: Modem Callout, Modem RI is CD, Modem Autoconfigure Modem state: Idle Modem hardware state: CTS noDSR DTR RTS, Modem Configured Special Chars: Escape Hold Stop Start Disconnect Activation ^^x none - - none Timeouts: Idle EXEC Idle Session Modem Answer Session Dispatch 00:10:00 never none not set Idle Session Disconnect Warning never Login-sequence User Response 00:00:30 Autoselect Initial Wait not set Modem type is default. Session limit is not set. Time since activation: never Editing is enabled. History is enabled, history size is 20. DNS resolution in show commands is enabled Full user help is disabled Allowed input transports are none. Allowed output transports are pad udptn telnet rlogin ssh. Preferred transport is telnet. No output characters are padded No special data dispatching characters
Router#show interface FastEthernet0/0 is up, line protocol is down Hardware is PQUICC_FEC, address is 0007.8580.6939 (bia 0007.8580.6939) Internet address is 192.10.0.3/24 MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation ARPA, loopback not set Keepalive set (10 sec) Auto-duplex, Auto Speed, 100BaseTX/FX ARP type: ARPA, ARP Timeout 04:00:00 Last input 05:21:55, output 00:00:02, output hang never Last clearing of "show interface" counters never Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 94 packets input, 11826 bytes Received 94 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored 0 watchdog 0 input packets with dribble condition detected 2861 packets output, 207183 bytes, 0 underruns 37 output errors, 0 collisions, 2 interface resets 0 babbles, 0 late collision, 0 deferred 37 lost carrier, 0 no carrier 0 output buffer failures, 0 output buffers swapped out Serial0/0 is down, line protocol is down Hardware is PQUICC Serial in async mode (TTY1) MTU 1500 bytes, BW 9 Kbit, DLY 100000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, LCP Closed, loopback not set Keepalive not set DTR is pulsed for 5 seconds on reset Last input never, output never, output hang never Last clearing of "show interface" counters 07:29:05 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/0/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 6 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions
Hi Bill,
You may wish to investigate Cisco's WIC-1T Sample Configuration:
Hope this helps.
Brad Reese
to access the modem, you would use a reverse telnet session.
see Cisco doc
The reason that you attempt to telnet from the router to itself on port 2001 is failing is that the interface
192.10.0.3 is down.
Plug something in to bring it up and that will be one problem out of the way. IF you dont have the facilities to bring up the ethernet port then create a loopback interface with any address you care and use that. Of course the "localhost" address should work (127.0.0.1) but I have had problems with that (not on cisco) and don't trust it.
"When the port is in data terminal equipment (DTE) mode, the CONN LED indicates that Data Set Ready (DSR), Data Carrier Detect (DCD), and Clear To Send (CTS) have been detected. When the port is in data communications equipment (DCE) mode, it indicates that Data Terminal Ready (DTR) and Request To Send (RTS) have been detected."
Yours says: CTS noDSR DTR RTS
I forget what to make of that. Check out the telnet and report back.
show run int se 0/0 woudl be good. also details of the cable(s)
"Merv" wrote in news: snipped-for-privacy@m79g2000cwm.googlegroups.com:
Thank you both for the leads. I was able to telnet to the modem after I connected my laptop to the ethernet port on the router, this brought fastethernet0\\0 up/up. But when I terminated the telnet session IOS told me that the modem autoconfigure failed. I'm wondering if this because the serial interface is still down/down (no matter what I do, proper cables, power all around, IOS configured as cisco recommends). At this point I have taken off the ip address to see if it was causing a problem. Or weather I just have to get to the point where I start a call and it will come up. Any comments on this would be appreciated.
Serial0/0 is down, line protocol is down Hardware is PQUICC Serial in async mode (TTY1) MTU 1500 bytes, BW 115 Kbit, DLY 100000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, LCP Closed, loopback not set Keepalive not set DTR is pulsed for 5 seconds on reset Last input never, output never, output hang never Last clearing of "show interface" counters 02:12:59 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/0/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 86 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 0 packets output, 0 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions
after terminating telnet session.
11:31:23: %TTY-3-AUTOCONFIG: TTY1: Modem auto-configuration failed
Cisco doc on router modem connections says this is the normal idle state.
I hooked my laptop into the ethernet port and was able to telnet to the modem.
modemcap entry Multitech:MSC=&FS0=1&C4&D3$SB115200 ! ! interface FastEthernet0/0 ip address 192.10.0.3 255.255.255.0 speed auto ! interface Serial0/0 physical-layer async no ip address encapsulation ppp ! ip classless no ip http server no ip http secure-server ! ! control-plane ! ! line con 0 line 1 modem InOut modem autoconfigure type Multitech transport input all stopbits 1 speed 115200 flowcontrol hardware line aux 0 line vty 0 login modem autoconfigure discovery line vty 1 4 login ! end
I checked twice, I have the right cable Cisco CAB-232MT 60 pin at router and 25 pin at modem (males) Is it possible my modem cap is wrong? Should it have the MSC= at the front? When I terminate the telnet session IOS tells me the modem auto configure has failed.
11:31:23: %TTY-3-AUTOCONFIG: TTY1: Modem auto-configuration failed Can you shead some light on that?
Thanks
Sorry not really. I just spotted the telnet thing. I have never used a modem on a router.
nice.
I can just offer general troubshooting advice.
Remove everything you don't need from the config and try basic stuff.
E.g. when you send the modem AT go you get OK back?
Look at the debugs described in the docs.
DEBUG has a few gotchas.
In general possible performane hit is /huge/. Howerer that is not an issue here.
logg buff deb logg buff 30000 logg con
If you are telnetted to the router you need to issue
term mon
term no mon ! to turn off
sh log
In general I don't have console logging on for production.
Please post the complete config as it now stands after you remove the following:
config t
line vty 0 no modem autoconfigure discovery end wri mem
Also for future debugging, suggest you configure:
config t logging buffer 10000 debug no logging console end wri mem
see Cisco doc "Understanding the 1-Port Serial WAN Interface Card (WIC-1T)"
which also referrs one to the following Cisco doc for more info on using the WIC-1T in async mode "If your platform supports async, then use the physical-layer async command for async mode. Such an application is useful to connect an external modem to the router. Refer to the document 2 Port Async/Sync WAN Interface Card (WIC-2A/S) for an example."
see Cisco doc "Configuring Dialout Using a Modem on the AUX Port"
In your case the modem is not on the AUX port but the serial 0/0 which has been configured into async mode op operation
Hi Merv,
They will not need a CCO Login with the following two web page alternatives.
2-Port Async/Sync WAN Interface Card (WIC-2A/S):
Configuring Dialout using a Modem on the AUX Port:
Sincerely,
Brad Reese Cisco Repair
