Cisco 837 with Qwest DSL
Sep 23, 2006 2 Replies
Cisco 837 with Qwest DSL open original image
I am looking for any information on how to configure an 837 ADSL router to work with Qwest DSL. Does anyone have a sample config?
You may wish to investigate:
Cisco 800 Router Documentation:
Cisco 837 Configuration Wizard:
Cisco 837 Basic Configuration:
Cisco 837 Firewall Configuration:
Cisco 837 Firewall PPTP Configuration:
Cisco 837 Business Configuration:
Cisco 837 ADSL IPSec Configuration:
Cisco 837 ADSL Firewall IPSec configuration:
Cisco 837 GUI Config:
Hope this helps.
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Cisco Technical Forums
The cisco docs for PPPoA with PAP work just fine with Qwest (or any 3rd party ISP that supports PPPoA).
Just set the PVC to the right value for Qwest (0/32).
(Note: this example assumes real routed IPs, even though it uses private IPs in the list, it doesn't cover a NAT config if that is what you are going for).
