1720 WIC-1T and WIC-1DSU-T1
Nov 17, 2006 4 Replies
Jump to replies (4)
1720 WIC-1T and WIC-1DSU-T1 open original image
currently trying to convert from frac T1 to full T1
1720 has WIC-1T in slot WIC0 (currently working)
stuck the WIC-1DSU in WIC1 and WIC1(on router) light says ok
CD light on 1DSU card is NOT on
ISP sees loop back to end of cable (thru smart jack, and drop cable from smart jack)
pressing loopback button on 1DSU card, still doesnt see it
took both cards out, stuck 1DSU card in WIC0 slot, still no CD light
SHOW DIAG shows: WIC Slot 1: Unknown WAN daughter card
docs shows 1DSU card will work on all IOS
IOS is Version 12.1(8c)
do i need to somehow "turn-on" or enable the card?
TIA
I'll assume you made the necessary changes in the config, you didn't mention it.
Is the new card a wic-1dsu-t1 OR a wic-1dsu-t1-v2? the newer card requires a newer IOS, your "Unknown WAN daughter card" is typical of this issue.
The WIC-1DSU-T1 V2 is not supported in the 1700 series, it's not simply a software issue..... You MUST use a V1 card in there. If it is a V1 card, it is not hot swapable, router must be rebooted for it to be recognized properly.
its a V2
looks like i need the new IOS
now i gotta figure out how to get the IOS...i need to f> I'll assume you made the necessary changes in the config, you didn't mention > it.
got it now, cant get back to my internal gateway have: ip default-gateway 10.0.1.30 ip classless ip route 0.0.0.0 0.0.0.0 Serial0.1 ip route 10.0.1.0 255.255.255.0 10.0.1.30 no ip http server
that should do it right? i have a route and the default ping and tr dont get me there...what am i missing?
also, memory question... Head Total(b) Used(b) Free(b) Lowest(b) Largest(b)
Processor 808A7A54 16090540 1719668 14370872 14219884
1427599
the bin file is 9meg...where is it going? can i have both there on the box?
TIA
Stanguru wrote:
