WIC-1T doesnt work on 2621 and 2811
Jul 17, 2006 9 Replies
Jump to replies (9)
WIC-1T doesnt work on 2621 and 2811 open original image
Hi I bought one WIC-1T and once installed it detects but it wont work, the light is a constant orange amber, Ive tested with ISP all sorts, encapsulations etc, but it wouldnt work, I tested on a 2811 and in a 2621 and detects but the light keeps amber, I tested everything, encapsulation etc (my end is a DTE), then I tested the cable into a built in 2500 serial card and it worked, so the conclusion was the WIC-1T was faulty. I debuged and it sends keepalives but it wont receive any and is always reseting.
I asked for a replacement but this one doesnt even detect, the message is: "NM slot 0, wic card has an unknown id CE", Ive tried in both routers.
2811 with 2FA cisco ios adventerprisek9 12.4-6.T
2621 with 2FA cisco ios 12.2(9)
Thanks
Don't waste more time with it...ask for a replacement.
thanks for your reply, sure I did that :) its weird, the first one detected but would connect (its a leased line), this one doesnt even detect, and wIC-1t its more than compatible with both routers.
le_brito wrote:
Sounds like you had two bad ones in a row.
There shouldn't be any problem supporting a WIC-1T in either router, that card has been supported from the start in the 2600 line, and hasn't changed any.
UNBELIAVABLE, I received my third WIC-1T and it still doesnt work in both routers! sh diag: unknown wan daughter card unknown eeprom version 210 EEPROM format version 210
I always try the card first on the 2600, can it damage the card? but the first one detected quite simple but it wouldnt work in both routers. and I unlucky or are my routers f***ed? everything works fine.
Thanks
camocas wrote:
Cisco docs indicate that 2600 needs 12.2(13)T or 12.2(11)YT to support
see
Well, I had to get a Version 2 card for my 2611. I could not use the old WIC-1T from my 2511.
Gordon Montgomery Living Scriptures, Inc snipped-for-privacy@lsi.com (anti spam - replace lsi with livingscriptures) (801) 627-2000
How'd you get a WIC into a 2511?
Are you confusing 2611 with 2811 and 2511 with 2611? Are you confusing WIC-1T with WIC-1DSU-T1? There is no version 2 of WIC-1T.
Oops, yep I was. Sorry.
