internet access through wireless router
I have recently purchased and successfully connected a Dynamode wireless router. All my connection tests show the router working, yet I cannot access any websites other than google and bbc.co.uk. Ping tests give the same result. Can anyone help?
KLR
On Mon, 4 Feb 2008 12:55:19 -0800 (PST), KLR wrote in :
Tired a wired connection to the router. Turn off all security while troubleshooting. Run "IPCONFIG /ALL" in a CMD window and post the exact results here.
John Navas
Windows IP Configuration
Host Name . . . . . . . . . . . . : Kim Primary Dns Suffix . . . . . . . : Node Type . . . . . . . . . . . . : Unknown IP Routing Enabled. . . . . . . . : No WINS Proxy Enabled. . . . . . . . : No
Ethernet adapter Local Area Connection:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : VIA Rhine II Fast Ethernet Adapter Physical Address. . . . . . . . . : 00-40-D0-6D-F0-61 Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 192.168.1.3 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DNS Servers . . . . . . . . . . . : 192.168.1.1 Lease Obtained. . . . . . . . . . : 04 February 2008 20:42:23 Lease Expires . . . . . . . . . . : 04 February 2008 21:42:23
Ethernet adapter Wireless Network Connection:
Connection-specific DNS Suffix . : Description . . . . . . . . . . . : USB 54M Wireless Network Adapter Physical Address. . . . . . . . . : 08-10-17-0A-15-9D Dhcp Enabled. . . . . . . . . . . : Yes Autoconfiguration Enabled . . . . : Yes IP Address. . . . . . . . . . . . : 192.168.1.2 Subnet Mask . . . . . . . . . . . : 255.255.255.0 Default Gateway . . . . . . . . . : 192.168.1.1 DHCP Server . . . . . . . . . . . : 192.168.1.1 DNS Servers . . . . . . . . . . . : 192.168.1.1 Lease Obtained. . . . . . . . . . : 04 February 2008 20:42:30 Lease Expires . . . . . . . . . . : 04 February 2008 21:42:30
KLR
Thank you. This shows your wireless adapter connected to the wireless access point and properly configured. Does the wired connection work better for the Internet? Disconnect the wired connection, and run "tracert ns1.sprintlink.net" in a CMD windows and post the exact results here.
On Mon, 4 Feb 2008 13:07:41 -0800 (PST), KLR wrote in :
John Navas
The wired connection gives the same results as when using a wireless connection.
Tracing route to ns1.sprintlink.net [204.117.214.10] over a maximum of 30 hops:
1 2 ms
KLR
Since the traceroute works, my guess is a browser configuration issue. Things to try:
  • Check for and turn off any Proxy settings in Internet Options.
  • Reset all Security settings to defaults.
  • Reset *all* settings to defaults.
  • If you're using IE, try Firefox or Opera.
On Mon, 4 Feb 2008 13:23:26 -0800 (PST), KLR wrote in :
John Navas
I have long wondered about Internet Options.
Do they affect all browsers, or only Internet Explorer?
Maybe I have overlooked them, but I never see references to Internet Options in Netscape or Firefox.
Maybe this should imply an answer to my question above, but I can't figure it out.
If you are inclined to email me for some reason, remove NOPSAM :-)
mm
On Tue, 05 Feb 2008 01:58:36 -0500, mm wrote in :
Primarily Internet Explorer, but some other Internet software can pick up and use those settings.
These are steps that might solve your problem.
John Navas
Can you really have two connections (one wireless, the other hardwired) to the same router and both to the internet at the same time on a Windows machine?
-nz
Rev. Newt Zest
On Tue, 05 Feb 2008 07:19:17 GMT, "Rev. Newt Zest" wrote in :
Sure, but all traffic will be routed to the interface with the lower metric for the route -- see
or
John Navas
